JK32SHO aka the cisco kid
Username: Kingtutus
Lincoln, Nebraska U.s.a
Post Number: 339
the box u made for Quentin sucks. the screws used only where 1 inch and barley went in to the sides. the box feel apart easily
Username: Joebruce
TC Sounds/DLS
Post Number: 2218
WTF?
Username: Cozce
Post Number: 92
x5
Username: Kingtutus
Post Number: 340
wtf spammer be gone
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 2...
Post Number: 6510
One dollar Bob.
Diamond Member
Post Number: 21709
ELVIS IS ALIVE!!!!
Username: Kingtutus
Post Number: 341
wtf
Username: Somedonniedude
Illinois United States
Post Number: 1828
How did it come apart? Got any pics?
Username: Kingtutus
Post Number: 345
the hole top lifted right off. srry no pics, i already fixed it
Post Number: 1829
Did it get battered in shipping?
Username: Gh0st_31
USF, FL USA
Post Number: 782
As far as i know there are screws and glue that hold his boxes together so the question is what did you do to make it come off? ;)
Username: Naledge503
Portland, Or
Post Number: 4056
Why didn't Quentin make this thread? And it seems as if this thread was made without contacting him first....why?
Username: Kingtutus
Post Number: 346
case i bought the box and might be buying the fi q from him to
Post Number: 1834
I doubt it just came apart. The glue does more work than the screws do, and I doubt JK didn't use glue.
Username: Jkidder
Worlds gunna end, In 2012
Post Number: 3657
you mean the scotch tape didnt hold it together? gtfo, show me some pics of the terribleness of my box and i'll gladly build you another free of charge. the only problem it had was i slipped when cutting the bottom baffles sub hole. it was repaired before shipping but didnt look the best. it was covered with another baffle anyway so you could only see it from the side if there was no sub.
the cisco kid
Username: Kingtutus
Post Number: 347
the glue and the srews didnt hold it the top came right off
Username: Th3pwn3r
I compensate...
Post Number: 8334
"the glue and the srews didnt hold it the top came right off"
Quite possible if the screw holes weren't pre-drilled or were stripped out. Where is your proof of this though? How do we know you didn't do something really retarded to make it come off?
Username: Kingandsons07
Lincoln, NE TEAM RD U.S.A
Post Number: 1071
hahahahaha "you didn't do something really retarded to make it come off"
Username: Kingtutus
Post Number: 348
well u can ask Quentin he say the screws in the box they didn't even go through the in to the side to hold the box together
