pretty much any other sub ill look at to if its better. but i would like some one to tell me why the sub is better. i don't want to buy something just because its what u have. after tomo i will be without a system... so i am kinda wanting to know fast.. that and an alt
Well if you want nothing but spl it seems like the best choice. Sx's can get real loud. plus that amp would work well with 2 sx's. they could take more power and probably get louder, but that amp will push them atleast nicely.
2 15s???? it doesn't have the cone area or is that the square ones?
the sx and the BL are almost the exact same when it comes to specs. but u can get more stuff with the BL.
the AQ i really dont know anything about. i didn't even know they 18s until the other day.
i say nothing but spl but i might go to one or 2 comps. ill go a tl and show off and pretty much just show off alot. but this is a daily driver also. and i do like to listen to music i don't have much time for comps cause i work weekends.
i just dont see any difference in the sw and bl. other than the sx is cheaper
