Bronze Member Username: Fritos2Post Number: 12 Registered: Apr-08 | Almani HA-750.2 2-channel 450rms watt at 4ohms. would this be good amp for a 12" type r alpine? |
Silver Member Username: Dirtrider125Post Number: 135 Registered: Apr-07 | if u need a amp to power it at 4 ohms i have a kicker kx450.2 for sale it will do 550 rms @ 4 ohms i have pics |
Silver Member Username: Drant19DUB-C, TX Post Number: 893 Registered: Aug-07 | get a mono amp that does 800wmrs. is your sub a dual4ohm? |
Bronze Member Username: Fritos2Post Number: 13 Registered: Apr-08 | u sure?? i looked it up and it says 150x2 at 4 ohms |
Bronze Member Username: Fritos2Post Number: 14 Registered: Apr-08 | yes dual 4ohm. isnt it bad for the sub to overpower it? |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 5327 Registered: Dec-05 | not if you set your amp properly. IMO you should get a kicker Zx 500.1 |
Platinum Member Username: Rovin1 15 = 149.1DBsTrinidad & T... Post Number: 13739 Registered: Jul-05 | type r can handle 700wrms easy so id get a amp like http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19319 ... |
Gold Member Username: 420alldaylongPost Number: 3566 Registered: Sep-06 | I don't know sh!t about Almani products but if I was you I would get a good 500/700RMS @ 2ohm. Always try to use mono d class amps for subs but 2 channel amps will work fine.(efficiency is the key) Whats budget for amp? |
Bronze Member Username: Fritos2Post Number: 15 Registered: Apr-08 | like under $200. would it be bad if amp is only 5-200hz? the type r goes to 500 or something like that |
Silver Member Username: Drant19DUB-C, TX Post Number: 902 Registered: Aug-07 | your going to put your low pass filter at around 80hz. |
Bronze Member Username: Fritos2Post Number: 16 Registered: Apr-08 | so u usually dont have any sub go over 200hz anyway or wat? |
Bronze Member Username: XeighPost Number: 12 Registered: Mar-08 | I actually just recently bought a 12' Type r sub and i'm trying to pick the right amp for it. I was looking at the Alpine PDX-1.1000 amp i have the dual 4ohm version of the type r, I currently have a MRP-F450 amp for my speakers so i believe i need a cap for my car as well. I'm a bit new to car audio so any guidance would be much appreciated. |
Bronze Member Username: Fritos2Post Number: 17 Registered: Apr-08 | i was wonderin also when about would u need a capacitor like 1000watts 900 700 ect. and does a capacitor actually matter and make a diff. |
Silver Member Username: Drant19DUB-C, TX Post Number: 910 Registered: Aug-07 | Justin make your own thread. adfasn: NO CAP, it wont help you at all. your sub shouldnt play anything over ~80hz, if your sub is a dual4ohm sub then get a kicker zx750.1 it will put 800rms to that sub and the type-r will love that much power. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 5338 Registered: Dec-05 | You will need a cap when you have a HO alternator, BIG 3, batteries etc. It's not as cool as you might think like HEY! let me put a cap and my problems are solved.. H3LL NO |
Silver Member Username: Drant19DUB-C, TX Post Number: 923 Registered: Aug-07 | caps are only useful in the CORRECT set up! yours is not needing a cap. but like i said earlier, if your sub is a dual4ohm, get the kicker zx750.1 OR something that will put 700-900rms @2ohm |
