THE BETTER BUY
Username: Banginfi1025
COVENTRY, RI USA
Post Number: 50
IM LOOKING INTO 3 SETS OF SUBS I WANTED TO KNOW WHATS THE BETTER BUY. IM LOOKING FOR LOUD CRAZY CLEAN BASS. I PREVIOUSLY BOUGHT MONSTER CABLE WIRING 0 GUAGE WITH THE BIGGEST GUAGE MONSTER RCA'S A OPTIMA BATTERY AND A 220 AMP HIGH OUT PUT ALT. IM PUTTING MY SYSTEM IN A 1997 CHEVY BLAZER SO MY QUESTION IS FOR A BOX 38.5IN WIDE, 20 INCH HIGH AND 25 INCH DEEP WITH A 5 INCH PORT IN THE FRONT AND THEY WILL BE FACING MY HATCH WHEN INSATLLED
THE SUBS
TWO 15 INCH L7'S
TWO 15 INCH RE SX'S
TWO 15 INCH AUDIOQUE HD3
WILL BE POWERED WITH A HIFONICS 2600 WATTS RMS AT 1 OHM (ALREADY ORDERED no turning back)
SO WHATS THE BEST BUY ?
COVENTRY, RI USA
Post Number: 51
what type of port system should i do i was thinking a l shape should do it
Username: Insearchofbass
Post Number: 9244
assuming that you want more loud than clean im going to say audioque hdc 15's and yeah do a slot port with about anywhere from 2.00 to 2.50 cubic feet net per sub
Username: Hurricanebr1an
Western Burbs of Chicago, IL Usa
Post Number: 534
SO LET ME GET THIS STRAIGHT...YOU HAVE THE BOX ALREADY AND YOUR CHOICE IS TO EITHER GET SQUARE OR ROUND SUBS TO PUT IN IT..
HOW ARE YOU GOING TO WORK THAT?
Post Number: 9245
the car we did has two audioque hdc 12's in aprox 3.45 cubic feet net tuned to 37-38 hz and hits very well on the low end still
Username: Extrmndor3
Http://illuzonemu.serv..., ^^^Sick Game
Post Number: 7925
the best buy is the competitor of circuit city sometimes u get crazy deals there.. but mostly on pcs and all that crap and not in the car audio department
Username: Somedonniedude
Illinois United States
Post Number: 1549
lol.
Whats your budget?
Username: Frkkevin
Team DLS, Funky Town /...
Post Number: 5099
I loved my SXs for streetbeat.. too loud to listen to on full tilt but more SQ than the others you listed
but yeah, budget would help.. could be some other subs out there for you :-)
Username: Drant19
DUB-C, TX
Post Number: 961
SX out of those 3 choices..
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 2714
I have an dual 4 SX 15" with a brand new recone that would be perfect for you. $220 shipped and has never been used before with the recone.
http://www.caraudio.com/forum/showthread.php?t=316273
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 5100
Good price.. wholesale cost on that sub went up $20 from last I checked.. so pricing keeps going up on them :-(
Username: Safe_cracker
Chicago, IL US
Post Number: 4530
Ya, SX is the shiottt!!! Polo...
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2501
You've been asking this exact same question since the day you joined. Make a choice and be done with it.
COVENTRY, RI USA
Post Number: 52
alright so from judging what you guys have said i should go with the sx's for clean and the l7's for just over the top loud that how im seeing it tell me if im wrong
Username: Nyyfan13
15 Mag USA
Post Number: 9643
Chicago, IL US
Post Number: 4531
Actually SXs are louder and can handle more power. I had one I ran a daily 2400 rms to it, on music then sold it and someone else played it for a while and then I think resold it lOl ? Polo..
St. Louis, MO / ASU
Post Number: 2716
SX>>>>L7.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2502
The L7s shouldn't even be on your list if you are comparing all these subs even up. The Audioque and RE will be both be as loud and sound better. Get whatever is cheaper between the AQ and RE and be done with it.
