Should i put a 12" type r in a sealed or ported box
Username: Dirtrider125
Post Number: 78
i already have a sealed box but cant decide if i should get a ported one. i will be powering it with a kx450.2 500 rms briged so it will be getting full amount of power. i want it to be loud but still sound good
Username: Ctmike
Ct.
Post Number: 6054
ported, anywhere from 32-35hz. works best for them imo.
Username: Hittin1
LakeCharles LA., La
Post Number: 278
x2^^^^
Post Number: 97
can someone make me a box tuned to 32 hz and i will pay u
Username: Ctmike
Ct.
Post Number: 6062
bj (fisher customs):
bj@fishercustoms.com
or
phil (woodlawn cabinetry)
www.woodlawncabinetry.com
both great quality, and very good c.s. either way you can't lose.
Username: Surferdude9371
Im BTL Bumpin
Post Number: 884
^both great box builders
Username: Joebruce
Mach5Audio M...
Post Number: 2056
I would go ported. Although when I had my Type-Rs I had them in a sealed box and they sounded nice and got pretty loud. Maybe try out your sealed box while youre having a ported one built and see how you like it then try out the ported and use whichever you like best. Oh and Fishercustoms FTW!!
