Username: Dloc WHITTIER,
CA
Post Number: 132 Registered: Jul-06
Tuesday, May 06, 2008 - 06:11 GMT i was thinking of buying four L7 15s....is there any other type of woofer out there that might cost the same but yet be a bit better if so let me know
Username: Killerzracing71 Post Number: 2158 Registered: Aug-05
Tuesday, May 06, 2008 - 06:58 GMT Theres alot better then those whats your Budget and what kinda vehicle do you have is it stock electricall are you willing to upgrade in the future and how much space do you have to work with
Username: Andrew571 Stillwater/Edmond,
Oklahoma
Post Number: 1782 Registered: Oct-05
Tuesday, May 06, 2008 - 08:12 GMT nope. L7s are the best out there. period.
Username: Insearchofbass Post Number: 9148 Registered: Jun-04
Tuesday, May 06, 2008 - 11:46 GMT "nope. L7s are the best out there. period." hes joking...in case you didnt know
CA
Post Number: 134 Registered: Jul-06
Tuesday, May 06, 2008 - 19:40 GMT its going on a expedition..i am going to upgrade the elictical soon....my budget is about 180 220 a speaker
Username: Tejcurrent Post Number: 1334 Registered: Apr-07
Tuesday, May 06, 2008 - 19:44 GMT I'd do the electrical first to protect your equipment.
Username: Shortysetnies Rock Vegas,
NC
US
Post Number: 2558 Registered: Mar-06
Tuesday, May 06, 2008 - 19:57 GMT yeah, electrical needs to be done before you start powering your equipment. whats your budget for everything? amps, subs, wire, elec., HU, box...
Username: Denali_on_22s I get Bucks like Milwa...
Post Number: 5701 Registered: Feb-06
Tuesday, May 06, 2008 - 20:43 GMT you need a HO alternator, big 3, and at least 1 battery in the back to run 3000+ watts. L7s will be the loudest for the money, but there are speakers that sound a lot better and get almost as loud for the same money.
CA
Post Number: 135 Registered: Jul-06
Tuesday, May 06, 2008 - 20:48 GMT reece what speakers would those be.....al i need is the alternator and the battery for the back
Username: Surferdude9371 Im BTL Bumpin
Post Number: 891 Registered: Mar-07
Tuesday, May 06, 2008 - 22:28 GMT cvr's? im not a big fan of the square woofer in my opinion it doesnt sound just right but im sure someone will call me out on that lol i had the solo x 18.
Username: Rovin 1 15 = 149.1DBsTrinidad & T...
Post Number: 13713 Registered: Jul-05
Wednesday, May 07, 2008 - 00:53 GMT how about 4 Fi SSD 15" - $209 each ...
Username: Tejcurrent Post Number: 1336 Registered: Apr-07
Wednesday, May 07, 2008 - 01:36 GMT Very nice subs, but from my understanding the L7s will have a bit more output (at the cost of sq of course, it just depends on the goals).
