Fig out what ohm model my sub is?
Username: Surferdude9371
Im BTL Bumpin
Post Number: 878
how do i go about doin this
Username: Joebruce
Mach5Audio M...
Post Number: 2052
If it doesnt say on the sub then get a DMM(digital multi meter) and put it on the coils.
Username: Th3pwn3r
I compensate...
Post Number: 7995
Patrick, take the woofer out of the box and then get yourself a multi meter and set it to ohms and tap the negative and positive terminals and make sure there's no pressure on the cone or suspension and that will give you a reading in ohms. It might be off by .1 as a lot of subs are. So for example a coil on a D2 sub might read 2.1 on the multi meter.
