Silver Member Username: Prozack52Cincinnati, 2-D615D4 Dia... Post Number: 306 Registered: Feb-08 | http://www.subwoofertools.com/forum/ported-box.asp?Ew=24&Eh=14&Dia=4&Xmax=18&Vd= 1&NumW=2&Vb=2&Fb=35&Qts=&Vas=&Fs=&CE=0 this is for 2 10" re sr series woofers |
Platinum Member Username: Rovin1 15 = 149.1DBsTrinidad & T... Post Number: 13641 Registered: Jul-05 | Thread: This design seem ok? NO ! u put 1 cuft as the sub displacement !? & why is it only 24" long ?.... |
Silver Member Username: Prozack52Cincinnati, 2-D615D4 Dia... Post Number: 307 Registered: Feb-08 | crap my bad how long would you have it sorry the displacement is .12 heres the new one but what wrong with 24inches lol http://www.subwoofertools.com/forum/ported-box.asp?Ew=24&Eh=14&Dia=1&Xmax=18&Vd= .12&NumW=2&Vb=2&Fb=35&Qts=&Vas=&Fs=&CE=0 |
Silver Member Username: Prozack52Cincinnati, 2-D615D4 Dia... Post Number: 308 Registered: Feb-08 | http://www.subwoofertools.com/forum/ported-box.asp?Ew=24&Eh=14&Dia=1&Xmax=18&Vd= .12&NumW=2&Vb=2&Fb=35&Qts=&Vas=&Fs=&CE=0 Better Rovin??? |
Silver Member Username: Prozack52Cincinnati, 2-D615D4 Dia... Post Number: 309 Registered: Feb-08 | http://www.subwoofertools.com/forum/ported-box.asp?Ew=28&Eh=14&Dia=1&Xmax=18&Vd= .12&NumW=2&Vb=2&Fb=35&Qts=&Vas=&Fs=&CE=0 or this??? |
Platinum Member Username: Rovin1 15 = 149.1DBsTrinidad & T... Post Number: 13642 Registered: Jul-05 | well that new design looks pretty good 24" is decent too since if u make it longer u will notice the port bends even more - straighter the port the less restrictive it is u can tune that 1 or 2 hz lower if u wish ...... |
Platinum Member Username: Rovin1 15 = 149.1DBsTrinidad & T... Post Number: 13643 Registered: Jul-05 | on 2nd thought that red piece needs be at least the width of the diamter of the 2 subs combined so whats the EXACT diamter of 1 sub ? ex -if 1 sub is 11" across , then that red piece should at least be 22" ..... |
Silver Member Username: Prozack52Cincinnati, 2-D615D4 Dia... Post Number: 310 Registered: Feb-08 | http://www.subwoofertools.com/forum/ported-box.asp?Ew=28&Eh=14&Dia=4&Xmax=18&Vd= .12&NumW=2&Vb=2&Fb=33&Qts=&Vas=&Fs=&CE=0 this is it tuned at 33 hertz and they are only 10" drivers two of them so 24inches would work and so would 28 so which one should i go with this is the design for 28 inches |
Silver Member Username: Prozack52Cincinnati, 2-D615D4 Dia... Post Number: 311 Registered: Feb-08 | they are 2 re sr audios |
Platinum Member Username: Rovin1 15 = 149.1DBsTrinidad & T... Post Number: 13644 Registered: Jul-05 | er did u know : a 10" sub does not mean its extenal dimentions are 10" a econo pioneer external dimentions are actually 11" across if u have ur subs nearby go measure em now & report what u find out ..... |
Platinum Member Username: Rovin1 15 = 149.1DBsTrinidad & T... Post Number: 13645 Registered: Jul-05 | just saw on their site Overall Diameter - 10.25" this should be alright http://www.subwoofertools.com/forum/ported-box.asp?Ew=26&Eh=14&Dia=1&Xmax=18&Vd= .12&NumW=2&Vb=2&Fb=35&Qts=&Vas=&Fs=&CE=0 ...... |
