Help choose Amp
Username: Kenkenni
Post Number: 58
I am purchasing 2 Power Acoustik PW3-1OHs
that are dual 4 ohm voice coils rated at
700w rms 2000w max. I want to push them at 80% to max the full rms rating. Should
I go with one of the mono amps on the PA
web sight or can you recommend an affordable amp in the $500 or less range.
Username: Insearchofbass
Post Number: 8971
please dont purchase the power acoustic subs you can do better...whats your budget
Post Number: 8972
my bro has a brand new RD alpha 12 version 2 dual 2 ohm coils for 275 shipped and thats a steal for that sub
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2403
Like Sean said, definitely do not buy those subs. There is so much better out there. How much are you looking to spend on subs?
Username: Kyle_lowe
Post Number: 881
elemental designs nine.1
audioque aq1200d
either would work
Username: Loc_out
Santa Ana, Ca Resonant Eng...
Post Number: 1978
Kyle do you already have those sub?
Username: Hurricanebr1an
Western Burbs of Chicago, IL Usa
Post Number: 429
Second the aq1200d.
Perfect amp for the job.
Username: Kenkenni
Post Number: 59
Thanks for the replies so far. Has anyone
heard these subs in person? I don't
have many choices on 10" subs that will
fit in my box. I have a couple of Pioneers thats been in my truck for the last year that I'm looking to replace.
PAs new products appear to be better quality than their older products.
For the price and ratings of this sub I
think it should be just fine. I still
have a brand new set of MOFO 10s from a couple of years ago that won't fit in my current box. I'll use those in my next vehicle.
Username: Kenkenni
Post Number: 60
Oh I forgot.
I don't need the biggest baddest subs. Just something powerful but not overwhelming. I don't usually spend more than $150 per sub. And no more than $500
for an amp. Thats because there are lesser known brands out there that in some cases outperforms the expensive stuff.
Post Number: 431
specs on your box...then we can recommend better subs.
how much cu ft?
sealed or ported?
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2406
Why don't you build your own box?
Username: Kenkenni
Post Number: 61
I don't have the skils , tools, or
patience to attempt to build my own box.
It is beyond my comprehension. Also my
job requires me to travel to different
states so I really don't have the time
needed. I have a 2001 Dodge Ram quad cab
and if you've seen the rear seat area
you would see how your options are limited. I went to a shop down here that
said an order for me to fit a custom box
for the MOFOs the seat would have to be
raised almost 12 inches.I think thats too high as I still want a couple of people to fit back there.
Username: Joebruce
Mach5Audio M...
Post Number: 1923
Have BJ Fisher build you a custom box. He does awesome work and prices are low.
www.fishercustoms.com
Send him an email.
Before you do that tho pick out some different subs. What is your budget? We can help you pick better subs for the money.
Username: Joebruce
Mach5Audio M...
Post Number: 1924
A pair of Mach 5 Audio 10" MAWs would sound very good and they are only 77 bucks each. Get you a nice 500wrms amp and call it a day.
