Bronze Member Username: GrandhustlePost Number: 63 Registered: Feb-07 | Hey guys I could use some help... I'm thinking about buying 2 13w7's, 2 1000/1s to power them, and a 500/5 for my door speakers UNTIL I started hearing everyone and their moms saying that it's not worth it, or the subs will smoke, or the earth will end when you buy them. Not receiving good feedback for them. Would it be better to get 1 12' Image Dynamics IDMAX12-D2 sub and power it with a Massive Audio P.1000 amp? My friend is willing to sell them to me for $400, Is that a good deal or would it be smarter to keep my setup or go for something else? I currently have 2 12' Alpine type R's powered with only 1 rockford fosgate 1000 watt amp punch series so I dont think thats enough. I'm looking for more bass because these don't push out enough. I want it to be more low frequency stuff that will make your throat giggle and hard to breathe http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2031 http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/2666860/vpcsid/0 /SFV/30046 http://www.hookedontronics.com/show_product_details.jsp?cid=14175&c=0804Froogle& b=Alpine_SWR-1222D |
Bronze Member Username: GrandhustlePost Number: 64 Registered: Feb-07 | Any ideas? |
Silver Member Username: Drant19DUB-C, TX Post Number: 680 Registered: Aug-07 | give a max budget. but from what you were sayin on the JL system sounds like you got some deep pockets. you can get better for the money than JL. However, 2 w7 would POUND! i would give them more than 1000wrms tho. look into: RD Audio Fi Treo Audiopulse Audioque Mmats Soundsplinter Ascendant Audio google any of those names and see what you come up with. |
Bronze Member Username: GrandhustlePost Number: 65 Registered: Feb-07 | I spoke to my friend and he referred me to the owner of a car audio shop and I asked him what he thinks is the best subwoofer and he said with his 18 years as manager, he has seen 1 15" MTX Thunder 9500 speaker destroy 2 13w7s. I couldn't believe it but he says the 13w7s break easily. Do you guys have any info on the MTX Thunders? I think I can get 2 15"s for about $700. And my max budget on subs would prolly be $1000 for 2 and same for the amps. |
Platinum Member Username: The_image_dynamicSan Diego, California Post Number: 3678 Registered: Dec-06 | If you can get an IDMAX 12 and a Massive P1000 for $400 buy them immediately. |
Bronze Member Username: GrandhustlePost Number: 66 Registered: Feb-07 | That good of a deal huh? Do you think Its enough? I was really thinking seriously about getting 2 15" MTX thunders 9500 series. |
Silver Member Username: Drant19DUB-C, TX Post Number: 687 Registered: Aug-07 | "he has seen 1 15" MTX Thunder 9500 speaker destroy 2 13w7s" ^^^^BULLSH!T^^^^^ how can MORE cone area and MORE watts lose? unless they were in a box made by John Wheeler... |
Silver Member Username: ExigeCincinnati Post Number: 222 Registered: Nov-07 | 9500's blow. There's my honest opinion for the night. |
Silver Member Username: Drant19DUB-C, TX Post Number: 697 Registered: Aug-07 | ^x2 |
Bronze Member Username: GrandhustlePost Number: 67 Registered: Feb-07 | I wanna try Fi's....... |
Bronze Member Username: GrandhustlePost Number: 68 Registered: Feb-07 | Im super confused. I want some LOUD bass but dunno what to go with |
Bronze Member Username: GrandhustlePost Number: 71 Registered: Feb-07 | Im super confused on what to get. |
Platinum Member Username: Dakangofkrunk16Boca Raton, Florida Post Number: 1472 Registered: May-07 | Get a amp kicker 2500 and a Fi Btl you'll be satisfy.. thats if you have the money Also would need to do Big 3 and get a H/O alt and batts tho, but it sound slike you got the money |
Bronze Member Username: GrandhustlePost Number: 72 Registered: Feb-07 | Is that the best I can get for my budget of $1000 for subs and $1000 for amps? And should I go with 1 15" or 2 12"s? |
Platinum Member Username: Dakangofkrunk16Boca Raton, Florida Post Number: 1474 Registered: May-07 | Well if you get the kicker 2500 and Fi BTL you will need to upgrade your Electric Charging System... Btl is about 500 that amp is about 500 on ebay... so you would have 1000 or so for your charging system HO ALT AND BATS |
Bronze Member Username: GrandhustlePost Number: 73 Registered: Feb-07 | ouch thats pretty steep. Do you have any ideas on the IDMAX 12 and a Massive P1000 amp? $400 a good price? and do you think that would satisfy me? |
Platinum Member Username: Dakangofkrunk16Boca Raton, Florida Post Number: 1482 Registered: May-07 | i Dunno neva heard one.. i hear they are good... You could get a AQ HDC3 18 or 15 would be louder then the 12 But it about if you have the room But can't go wrong with a 18inch for 289 or the 15 for 249 Dual 2 |
Bronze Member Username: GrandhustlePost Number: 74 Registered: Feb-07 | Will it fit though? I've got an 08 Chrysler 300 and Im not sure how big the box needs to be? |
Platinum Member Username: Dakangofkrunk16Boca Raton, Florida Post Number: 1486 Registered: May-07 | HMMMMm... 300's have big trunk.. measure the trunk.. to what you can fit not the hole trunk.. you know what i mean then use this formula H X W X D Divided By 1728 |
Silver Member Username: Drant19DUB-C, TX Post Number: 706 Registered: Aug-07 | if you have $1000 for subs and $1000 for amps... why were you looking at (2) JL 1000/1 AND (2) JL 13.5w7 AND a 500/5?????? you cant get all that for $2000... |
Bronze Member Username: GrandhustlePost Number: 75 Registered: Feb-07 | Well, I can get a 1000/1 and 500/5 for $500 and im sure I can get another 1000/1 for 400-500 if I find a good deal and 2 13w7's for 1000 would be around 2000. But thats beside the point. My question is do you think its worth it and also, for that much money, can i do better than JL audio? I've heard nothing but good things about the Fi's. Now Im just wondering what setup to go with on the Fi's |
Silver Member Username: Drant19DUB-C, TX Post Number: 708 Registered: Aug-07 | if your going to run that much power, then you really need to budget in a HO alt. you wont be able to run much more than 1000rms on a stock alternator. |
Platinum Member Username: Nd4spd18Northwest PA Post Number: 7250 Registered: Jul-06 | I guess I'm a bit late but, MTX blows That is all |
Bronze Member Username: GrandhustlePost Number: 76 Registered: Feb-07 | Not too late. Any info on the Fi's? |
