70 amp alternator 4 gauge cable. 84% efficency
Username: Howtoeatapencil
Post Number: 30
can i run 1000watts out of an 84% efficient amplifier, if i have 4 gauge wire(17 feet) and a 70 amp alternator?
Does the fact that my car's lockes, windows, and mostly everything is manual?
Username: Nd4spd18
Northwest PA
Post Number: 7200
Probably, assuming you not going to go around blasting test tones out of it
Post Number: 31
haha, nope just music. And if i ever turn it up to 1000 watts it would be for a very short time
Username: Waresgaragestereo
Fort Valley, GA
Post Number: 38
you shud be ok
Username: Insearchofbass
Post Number: 8754
well im going to say no you wont be ok if you crank it...that 70 amps is not at idle only when driving...plus it takes amperage to run the cars electronic needs...but you will soon find out...and music can be almost as bad as test tones...its still frequency based...watch your volt meter with music on low notes and youll probably see what I mean
Diamond Member
Username: Rovin
Post Number: 13489
would advise u add a extra batt & a volt meter upfront to keep an eye on it but it should be alright as long as u dont play it max for long periods ...
Username: Drant19
DUB-C, TX
Post Number: 615
where can you get a volt meter? i want one for up front!!! how much do they cost?
Username: Big_edge_head
Milwaukee, Wisconsin MY SUBS GET ...
Post Number: 1826
Autozone or any car parts store will have them. For a simple one it'll only cost like 15-20 bucks. If you wanted something nicer like a digital one than they usually go for a lot more.
Username: Nd4spd18
Northwest PA
Post Number: 7210
Get a digital one. The analog ones are not precise enough to be useful.
Diamond Member
Username: Rovin
Post Number: 13491
stinger makes a really nice 1 which comes in either red or blue display ...
Post Number: 8764
Rovin you finally did that new sub install...what sub was it again...how much power and at what port tune
"1 15 = 149.1DBs"
Username: Nd4spd18
Northwest PA
Post Number: 7222
Yeah I have installed a few of those stinger ones. Actually I just put one in dwight's car at the 3/15 meet.
Fort Valley, GA
Post Number: 58
3/15 meet.
you're in NorthWwat Pa. do you know if any meets in middle ga? what car club do you have to be in to find out about these things?
Username: Nd4spd18
Northwest PA
Post Number: 7227
It was organized here on the forum, hosted by Sean and Scott S.
https://www.ecoustics.com/electronics/forum/car-audio/461134.html
Fort Valley, GA
Post Number: 63
cool
