NEED VIRUS & SPYWARE PROTECTION
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 2356
My computer is sayin its infected w/ both and I need something to clean it up. Any help would be nice. Thanks guys
Username: Livin_loud
COD4 Addict
Post Number: 2299
can't go wrong with AVG, mostly because its free.
Username: Frkkevin
Post Number: 4709
lavasoft ad-aware and spybot search and destroy are great spyware programs
i use pc-cillen for virus protection.. you can go to their site and do a free scan and delete virus through there without installing any programs
http://housecall.trendmicro.com/
Username: Mesodumm
Tri-City, Az Usa
Post Number: 424
http://www.free-av.com/en/download/index.html
Username: Mixmastaspig
Canada, Canada Canada
Post Number: 1526
Avast! and Spybot Search and destroy is what I use.
Username: Ironslave
Offutt AFB, Nebraska U.S.A.
Post Number: 562
i use avast myself and like it better then AVG, but i would change the sounds cause the defaults are annoying
Username: Ironslave
Post Number: 563
oh and a note, if your getting a popup from the tray that says you have viruses and liks you to a website to download some virus software then you have a really nasty virus, look it up online, there is some software that will clean it up for you because antivirus software cant get rid of it
Username: Big_edge_head
Milwaukee, Wisconsin MY SUBS GET ...
Post Number: 1618
What about trojans? Will it take them off?
Username: Th3pwn3r
Post Number:...
Post Number: 7232
Check out www.majorgeeks.com
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 5625
reformat your hard drive & reinstall windows
itll run good as new...just youll lose all your current info stored on your harddrive like pics songs ect...you could make a backup
Username: Tatonka
-[Team Audib...
Post Number: 1516
Right now the Top 2 antivirus/spyware combos out is Bit Defender and Zone alarm. Check both of them out.
Username: Jnoel
AIM= j69noel, KY
Post Number: 1054
AVG FTW
