How much
Username: Rockfordman2149
Champaign, Illinois US
Post Number: 135
How much would the big 3 cost?
Username: Joebruce
15 AQ HD3
Post Number: 1785
about 15 bucks and a BJ
Username: Livin_loud
COD4 Addict
Post Number: 2289
reach arounds are appreciated as well
Post Number: 136
and also where can i get a RD3250.1
Username: Joebruce
15 AQ HD3
Post Number: 1786
First contact Kevin,then meet him in some cheap motel,then suck him off while he is looking at Steve Millers pic. Im sure he'll hook u up then.
Username: Kingandsons07
Lincoln, Nebraska U.S.A
Post Number: 828
Username: Gh0st_31
USF, FL USA
Post Number: 711
quentin you're a real a hole
Username: Stateprop486
PA
Post Number: 940
not much at ll ull need probably 10-15 ft of 1/0 gauge wire which you can get from PAUL LARREA on here for $2 per/ft and then you need 0 gauge terminals probably like 6 of them 2 for each wire...n thats all, follow the link to see how to do the big 3.
https://www.ecoustics.com/electronics/forum/car-audio/456960.html
PA
Post Number: 942
for the RD3250.1 amp here's there website. you need to contact Kevin holden or Steve Miller.
http://www.rdaudio.net/index.htm
