System In a House (help please)
Username: Ducka
Shelby Township, MI United States
Post Number: 83
Could anyone explain how to hook up a car audio system including headunit, speakers, amps, and subs in a house? Or could they give me a wesite that would help? I know how to do most of it but I am not sure how to power it. Any help is good.
Thanks.
Username: Snarl2004
Digital Design 9515, Massive Audi...
Post Number: 2201
well you would need a power dc power converter. its easier to use a home stereo for speakers, then use a plate amp to power the sub. plate amps only work at 4ohms though
Username: Van_man
Boston South, MA
Post Number: 3555
this would be the easy way to go.
Short of that, you need a dc 12 volt power supply, then just hook it up like normal.
Username: Ducka
Post Number: 84
Thanks Snarl
Alright, can anyone telle or show me how everything would come together from there? Like what everything connects to?
Username: Ducka
Post Number: 85
HAHA good picture. What kind of DC power supply? can you send me a link?
Username: Van_man
Boston South, MA
Post Number: 3558
http://cgi.ebay.com/Astron-RS-35A-35-AMP-12-13-8-VDC-Volt-Power-Supply_W0QQitemZ 300201634778QQihZ020QQcategoryZ48708QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Nd4spd18
Northwest PA
Post Number: 6599
This topic has been brought up a thousand times and it's not feasible. Just get a home stereo.
Username: Snarl2004
Post Number: 2202
I'll get some pics of how mines set up later tonight and post them also if you have aim I can all to you about it there
Username: Ducka
Post Number: 86
Im sorry to bring it up if it has been brought up one thousand times, but I have seen it done before and I want to try it.
Username: Ducka
Post Number: 87
Thanks snarl, my aim is lilducka.
A pic is worth 1000 posts!!
Post Number: 14444
Yes it has been tried 1000 times b4 and all end with the same result.
Car audio was designed and intended for the ride, not your room.
Play as you will however..........
Username: Ducka
Post Number: 89
What is the same result?
Post Number: 14464
If properly powered you can use car audio drivers in a home. It's just not advisable to try and connect car amps and HU's tho. Pretty sparks and ppl screaming usually follow lol. Mainly because ppl try stupid things, like bringing the car battery inside their bedrooms and connecting a charger to it while powering the system.
"The same result" is if bass in the home is what you're after and you're serious about it then you will eventually leave the car amps and HU outside and power the drivers properly.
Username: Ducka
Post Number: 91
"Pretty sparks and ppl screaming usually follow lol."
LOL, Alright thanks. Ill just stick to powering the drivers then.
