Wiring sub diagram WITH 2 TERMINAL CUPS
Username: Mj23dynasty
They Love 2 Hate Me, Most Hated a... USA
Post Number: 1618
}Ok I'm trying to wire two 4 ohm DVC subs to a 1 ohn load. Now I kno how to do tht but I only know how to do tht to 1 terminal cup.
Can any1 make me a diagram of how 2 wire 2 dvc 4 subs to a l ohm to 2 terminal cups. I kno I'm dumb blah blah lol
Username: Stateprop486
PA
Post Number: 755
jus use 1 terminal cup then
A pic is worth 1000 posts!!
Post Number: 14280
Wait a minute. Are you trying to wire your subs to two seperate channels? (Two terminal cups)????
Post Number: 1619
}Well woodlawn put 2 terminal cups on my box for some reason but every dual sub setup I've owned the box always had two terminal cups?}
Post Number: 14281
One terminal cup will not be used.
PA
Post Number: 756
yea usually they put 2 terminal cups because sum ppl use 2 channel amps to run each woofer on a seperate channel. but u have the SAZ-1500D and thats a Mono Class-D amp so you would only have to use 1 terminal cup and just forget the other one exist.
Post Number: 1620
}Ok I thought something was wrong lol ok thanx paul.
Username: Kravenblood
Ohio Hmmm
Post Number: 376
lol or you can wire each sub to a 2 ohm load to each terminal cup then parrelel (sp) the 2 cups
Username: Rovin
4 10 Pioneer...
Post Number: 13241
^^^thats what i would do .....
Username: Nd4spd18
Northwest PA
Post Number: 6513
^^^^^ x3
Username: Kingandsons07
Lincoln, Nebraska U.S.A
Post Number: 768
^^^^^^x4
Username: Th3pwn3r
Post Number:...
Post Number: 7040
Wow, Dwight don't you learn anything that goes on here? What a bad question.
