Yes r no?
Username: Stateprop486
PA
Post Number: 560
i wanted to get an amp for my comps that i yet have a chance to install waiting for spring to come and i was thinkin of getting the kx200.2 r the kx350.2, do you guys think i would have to upgrade my alt or will it b able to do fine on stock alt. my alt is 80amps now, and im currently runnin an zx1000.1....and i dnt have the big 3 done r nething. possible? sorry for a newb question. lol just curious
Los Angeles, CA
Post Number: 18567
at least do the big 3. also go with the 200.2. you don't need that much power for your comps. you got the alpines right?
PA
Post Number: 562
yeah bro, lol the big 3 looks complicated. haha..i lookd at ma wires, and sum of them is hidden n stuff...i have an 99 camry..what is a good tool to use to cut thru the door panels to install the tweeters chad?
Los Angeles, CA
Post Number: 18569
dremel?
PA
Post Number: 565
lol is that only a guess? r not sure?
