Ported or sealed box for 2 12" cvrs?
Username: Leapoldstotch
Post Number: 48
my friend says he had it sealed with 700 to each sub and it flat out pounded. so im not sure?
Username: Nd4spd18
Northwest PA
Post Number: 6352
Ported > sealed
Post Number: 49
damn it :-( lol. i was gonna get the sealed for only 50 bucks 2. i might still get it. if ig et a ported tislike 100 +...
Username: Ctmike
Ct.
Post Number: 5866
are you talking about buying prefab boxes? if so don't do it, get a box made for them.
Username: •cam•
BC Canada
Post Number: 1973
You've already cheaped out on the subs; don't cheap out on the enclosure.
Username: 420alldaylong
Post Number: 3296
Go ported and build it yourself for way less than $100.
Username: B3n07
Louisville, Ky USA
Post Number: 723
ported ftw cvrs sound super good that way and if you need a good prefbed im not with recommending them butthe bass slammer series are good i got one in my car
Username: Nd4spd18
Northwest PA
Post Number: 6357
DO NOT buy a prefab ported box, the tuning on them is way too high, which makes them sound like complete crap
The box needs to be made for the subs. Heres some good box builders
www.fishercustoms.com
www.woodlawncabinetry.com
If you insist on a prefab box, make it a sealed one, and just check that the internal volume matches what the subs specify.
