Sealed vs. Ported
Username: Skibum12189
Cleveland
Post Number: 2624
trying to decide which to go with for my TC
i listen to a lot of rock as well as rap probably 50/50, and i don't think a ported 15 would sound all that great on the rock i listen to (lighter rock, higher bass) so i was thinkin sealed would be a happy medium....will it still get loud??
what should i dooooo???
Los Angeles, CA
Post Number: 18334
port that b!tch cal. doesn't matter on what kinda music do decide whether to port it or not. unless the tc sounds recomends sealed, port it.
the mag 15 sounded awesome with rock. it even kept up with the fast kickdrum bass of devildriver, the algonist, arch enemy, etc.....
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 5456
key word chad.."the mag"
what TC do you have?
Los Angeles, CA
Post Number: 18336
yeah i know dave. lol. thats why i said unless tc recomends sealed.
my rl-s didn't sound good ported at all. so if the tc is anything like it then yeah sealed.
should of been more clear.
Username: Jakeyplaysbass
Clarion Hert...
Post Number: 2415
Ported.
Chadly im sure your RL-s sounded horrible.....
Cleveland
Post Number: 2628
15" tc-3000
i think i will port it...what are anyones thoughts on 3.0 ft^3 at 32 hz?????
Cleveland
Post Number: 2632
Username: Mendonmafia
Post Number: 1226
maybe go bigger? just a suggestion.
Los Angeles, CA
Post Number: 18358
yea that seems a bit small for a 15.
Cleveland
Post Number: 2635
maybe 3.5 at 32 (((should i go 32 or like 33 or does it make no diff...going for sql))) ???
up
Post Number: 1232
ive had boxes tuned to 32 and 35 hz and could not really tell a difference. for a 15 i would do 3.5-4 cubes but i am guessing space it tight? if so then just put the largest box you can fit.
what kind of car?
Username: •cam•
BC Canada
Post Number: 1940
Dunno but doesn't TC build torquey motors? I've HEARD they sound peaky in large ported boxes. Dunno about the 3000 but Polo's 5200 is in 3.5 I believe.
