Will ice guard work for this
Username: Insearchofbass
Post Number: 8030
I have a 95 ford taurus gl and the fuel pump is very loud and im thinking of using ice guard to kill the noise any idea how much it will take
Post Number: 8031
just read about stuff called flex chad thats supposed to be similar
Username: Surferdude9371
Im BTL Bumpin
Post Number: 672
fuel pump is kinda important and not that expensive y not replace?
Username: Mendonmafia
Post Number: 1237
that ice guard sh1t sux. i am using it for matting now and it will not stick to the metal no matter what. i even used contact cement to try to get it to stick and it still barely holds. it will stick to anythibg else tho except the sheet metal lol.
Username: B3n07
Louisville, Ky USA
Post Number: 721
water pumps are cheap but hard to install
Im BTL Bumpin
Post Number: 676
i thought he said fuel pump which is very simple to replace?
Post Number: 8035
I was told that the loud fuel pump is common for ford...in other words nothings wrong with it...thanks for the tip on the ice guard mark...I wont buy it
