Blowin fuses
Username: Jladam415
Post Number: 35
Alright, so i just got my 1000/1 installed with my 12w7HO... first it blew 2 60's (assumed) than an 80 (ok it said to use a 100).... i bought the fuse holder and two 100 amp fuses, which lasted alot longer than the others but has now blown...
i have a stock alt silverado, 4 gauge power/ground... is there anything obvious that my problem? also it got very hott (the amp) is this normal for the 1000/1 ?
let me know because this stuff was way to expensive to be guessing....
Username: Denali_on_22s
The kids love my rhyme...
Post Number: 4214
thats not normal at all. 1000/1s are very nice amps.
Username: Jladam415
Post Number: 36
would you suggest anything? i know they are nice amps that is why i am trying not to fry it...
Username: Philly306
I get higher golf scor..., North carolina
Post Number: 889
check your ground
Username: Stateprop486
PA
Post Number: 445
mayb u have the wires mixed up...ground in 12v and 12v in ground....?
Username: Jladam415
Post Number: 38
it wouldnt even work if i did that would it?
PA
Post Number: 448
i doubt it, cuz i remeber on my zx1000.1 i accidentally did that and the fuses kept blowin right away.
Username: B3n07
Louisville, Ky USA
Post Number: 718
naw it would the 12 volt would need t get power from some where for the amp to turn on it might just be the power wiring is to small
Username: B3n07
Louisville, Ky USA
Post Number: 719
naw it wouldnt the 12 volt would need to get power from some where for the amp to turn on it might just be the power wiring is to small
Username: Somedonniedude
Illinois United States
Post Number: 979
What coils does your sub have? How do you have it wired?
Username: Jladam415
Post Number: 39
single, ive got it bridged but does it really make a difference on the monoblock?
i turned the gain down a half turn, its working for now, but ill probably go in tommorrow to get my whole system tuned...
