Are fi subs good
Username: Kicker2500
what would anyone go with
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 13791
yes they are good...but what is ur budget, and overall goal of your setup??
like 400 1000
a kicker 2500.1
2 15s
Username: Jtown
Team RD, Texas
Post Number: 2123
chaun, you realize who this is right?
what?
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2188
Thieves - what does it matter? He asked a legit question so let it go.
Me - with a 2500 I would suggest two 15" Fi BLs
Username: Naledge503
Http://www.LowDownForu...
Post Number: 3064
What happened Timmy?
I'm pretty sure he just wants SPL. On that much power, go with a pair of L7's and call it a system.
thank you
is that what you would recommend for that amp any other suggestions
what is he talkin about?
Username: Nyyfan13
15 MAG USA
Post Number: 8345
Doesn't matter who it is. Just help the guy, if its the Tim guy, then so be it. Not getting on your case Thieves. That was for everyone.
ME, are you set on Fi only? If you are, you could do 2 15" Q's or 2 15" Bl's. not enough power for 2 BTL's and too much power for 2 SSDs.
Username: Spivey17323
Dunellen, New jersey United states
Post Number: 1058
we say the same thing everything he posts and he doesnt listen so whats the point. hes just gonna make another thread asking the same question again.
Username: Snowball123
West Allis, WI United States
Post Number: 275
funny.
what are u people talkin about?
who is timmy
Post Number: 3067
I personally would do the Fi BL's like BCS said, but if you want strictly SPL with that amp, then you can do the L7's.
Username: Nyyfan13
15 MAG USA
Post Number: 8346
Dont worry about it ME. Some guy who sh1t on the forum last night. But thats besides the point of this thread.
Post Number: 1062
everytime*
whatever though.
Post Number: 7
omg i jus asked a simple question
\doesnt everyone ask questions about subs here
and im not timmy
Post Number: 3068
Ok to answer your question, ME. Yes Fi subs are good. I would go with a pair of 15" BL's with the amp you have.
Post Number: 8
so fi bls 15 inch is the best to go with
2 of them
Username: Tejcurrent
Post Number: 1079
I'd go with BLs. Yes, Fi is good.
Post Number: 9
ok ty
how much do they cost
anyone?
Post Number: 276
says on www.ficaraudio.com
Post Number: 13793
www.ficaraudio.com
Post Number: 10
ty
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2189
I would recommend that, correct.
Username: Kingandsons07
Lincoln, Nebraska U.S.A
Post Number: 650
i love my Q! what kinda car do u got? with that amp u will need an ho alt and 2 ext batt, big 3, what kinda box are they going in?
Username: 420alldaylong
Post Number: 3274
AudioQue HDC3
Post Number: 11
Configure Speaker: Ohm: dual 1 dual 2
P Chamfer: no yes +$10
Cooling: no yes +$40
Flatwind: no yes +$20
Daily or SPL: Daily SPL
Extreme Lead: no yes +$5
Universal:
what is all this?
Post Number: 3070
The HDC315's are out of stock though. Scheduled for more in stock at the end of the month.
Post Number: 277
those are extra options.
Post Number: 3071
Read about what those options do here..
http://www.soundsolutionsaudio.com/forum/index.php?showtopic=7154
Post Number: 12
do i need any of these options?
i am new to these subs
Post Number: 1063
if your buying two of them you would need to get 2 d2's that would work for your amp
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2193
Well it depends on your amp. If you're getting a 2500, yes there are some things you should add.
Post Number: 13
yes i have the amp
Post Number: 1065
he already has a zx2500
Username: Jtown
Team RD, Texas
Post Number: 2127
this is where you should read to find out whether you need the options or not
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2195
Agreed. Read that and it should be pretty clear.
Post Number: 14
ok ill call tomorrow
so its a rap
no other sub recommended
for the same price?
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2196
For the price, you really can't do much better IMO
Post Number: 279
you got a h/o alt already?
Post Number: 19
i think so
i have a 9c1 ex police impala
i have 2 gel batteries already
Post Number: 3275
http://www.soundsplinter.com/rlp_premium_series_subwoofer_information.html
Post Number: 282
good luck
Username: Denali_on_22s
The kids like my rhyme...
Post Number: 4053
Yeah, you won't need any options on those BLs. they will do fine stock. As for your electical system? Its going to need some juice to power that badass amp. Going with an HO alt and two batts along with the big three is a little over kill. If you get a big enough HO alt you should be fine running that system with the big 3 wiring done.
Post Number: 21
ty
thats all i wanted to know
i apologize for before.. i dont mean to be annoying.. its jus i dont want to spend alot of money on subs and makin a box and all that ..it gets expensive. im not complaining its jus i would like to know what would be the best subs for that amp ..i would like to know if all of you had this amp what sub would u put in your car..not jus a throw off answer..thats all
like i said if there is something better than fi . and would sound better then thats all the answer i need
Post Number: 284
just get the bl's.
Post Number: 1067
apology accepted. good luck on your install.
Post Number: 24
what is the big 3?
and what the diff between sq and spl
i never used those terms i jus bought what people told me 2
lol
Username: Big_edge_head
Milwaukee, Wisconsin MY SUBS GET ...
Post Number: 1422
big 3:
positive battery post to alt.
negitive battery post to chasis ground
engine block to chasis ground
Post Number: 286
sq is sound quality and spl is loudness.
Post Number: 1423
use 1/0gauge^
Username: Mendonmafia
Post Number: 1141
sq= sound qality
spl= loudness
sql = loud but still sounds good.
Post Number: 4057
okay, not being a dick but read these sites and you will know a lot about car audio.
the12volt.com
bcae1.com
As for SQ? SQ is sound quality. SQ is very subjective and different people like the sound of different things. It is namely little distortion and how transient the bass response of a subwoofer or any kind of speaker is.
SPL is sound pressure level. This measures how loud, in decibels, a system is.
SQL is a good blend of both.
I'm sure by the time I typed this there will be 10 answers for you already.
Post Number: 4058
What do ya know? Haha!
Post Number: 25
ok im looking for spl and sql
Username: Jtown
Team RD, Texas
Post Number: 2130
so, SQL
Post Number: 27
this is what i ahve now
4 12 inch evs
4 8 inch beymas
2500.1 kicker
900.4 kicker
i have alot of voice and highs
thats why its driving me crazy with the bass
i am tryin to equal it out
Post Number: 287
so your gonna add to that or start over?
Post Number: 29
i want to add bass subs to this
if any one here ever heard evs u would know what i need
Post Number: 30
yes sql sry
Post Number: 38
sql is what i need i guess
lol
so these subs are good for that
or are there something better?
i would wait for the audioque if its wort it but if there is no diff then why wait..
other sub options plz..
Post Number: 4067
dude... we told you what to get. you have explained to us that you want sql. you have explained what you already have. you have explained you dont want to spend money and be regretful. we have been through all this shitt and we told you to get the two 15 inch fi. bls ported. that is the forum consensus. if you seek other opinions there are alot of other forums. ecoustics votes for fi. bls.
Post Number: 49
there is this guy on here selling 2 15 fi qs for 350 are those better than the fi bls for sql
Post Number: 4071
you posted that in the other thread. there is no reason to post it here to. there is a response in the other thread. no offense, bud, but this is worse than potty training a chiluahua.
Post Number: 51
lol i know i am gettin diff answers in both
Username: Nickyp0219
Post Number: 612
Fi BLs. PERIOD. get the BLs.
/end thread
Username: Insearchofbass
Post Number: 7933
not to mess with anyone who likes Fi but I think its only fair to mention to ME that FI subs have been known to have tinsel issues
Post Number: 58
does anyone have the number fi tech?
i looked all up and down their web site and no number
Username: Surferdude9371
Im BTL Bumpin
Post Number: 626
im running 1 fully loade 18btl of my 2500.1 it sounds awsome. try contact on the website for the numba
Post Number: 59
i did
there is none
Username: Bonhamd
Northern, Michigan USA
Post Number: 232
just email them - sales@ficaraudio.com
