What wiring or kicker zx 350.4
Username: Dupe112309
Post Number: 18
kicker zx 350.4 4x60 rms....i was looking at 8 gauge wiring but how much will i need? i see something like 8 feet and 3 ft ground cable but im not sure how that works
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5175
depends where are you installing your amp. How close can you put your ground and for power wire, i think you'll need more considering you don't have it from the battery already
Post Number: 26
2000 mustang coupe......amp will be in the trunk. should i look at getting this done professionally? or do it myself?
