Hifonics 1606d and aq1200d are internally the same amp
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 1693
well the i just learned somethang the aq1200d and hifonics 1606d are almost the same amp internally.have the same board except the aq has 3x40 fuses and the hifonics has 2x70 fuses.hifonics is just a beefed up aq1200d haha
http://www.ddaudio.com/aq/AQ1200D_Guts.htm
http://i181.photobucket.com/albums/x60/get_er_dun90/GEDC0191.jpg
Username: Extrmndor3
Http://illuzonemu.serv..., ^^^Sick Game
Post Number: 7707
yeah... the 1606d is a strong lil amp
Username: Cblaze
Post Number: 1696
agreed
Username: Clouduz
Post Number: 303
my 1606d gives me no problems
Post Number: 7708
i been tru like around 6 hifonics bxi2006d their great amps.. they do get loud and they sound super smooth
Username: Audiosaab
Potomac, MD
Post Number: 120
couldent agree more on the nice amount of push the 1606d gives off, hifonics great for the price.... :D
Username: Nd4spd18
Northwest PA
Post Number: 5994
Same board DOES NOT EQUAL SAME AMP.........
Same board means jack sh!t, it's the quality of the components used.
Username: Cblaze
Post Number: 1698
didnt say they were the exact same amp
Username: Nd4spd18
Northwest PA
Post Number: 6005
" Hifonics 1606d and aq1200d are internally the same amp "
Fail.....
Username: Stateprop486
PA
Post Number: 281
i would def prefer AQ amp over hifonics...neday....
Username: •cam•
BC Canada
Post Number: 1859
I was gonna post almost exactly the same thing, MS. I was gonna put "Really?" above the quote, though.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 13699
blah..a watt is a watt.. same board same amp, to some degree...u will not be able to tell a difference...
Username: Nd4spd18
Northwest PA
Post Number: 6008
A watt is a watt in that one amplifiers watts are not better than anothers.
The differnce is build quality........
Username: Cblaze
Post Number: 1699
m.s how do u know the build quality of each?did u build the amps?have u put the amps side by side to compare them?sounds like u just dont like the name hifonics
Username: Cblaze
Post Number: 1700
oh my bad m.s u didnt say hifonics was junk but like i said,did u build the amps and have u compared them side to side
Username: Denali_on_22s
The kids like my rhyme...
Post Number: 3862
chauncey is right, that being said what does it matter. if you don't have problems mechanically with your hifonics then it's good to go. i ran my 1500d for a while with no problems.
Username: Cblaze
Post Number: 1702
no probs.i just posted this cuz i was drunk and like hmm haha
Username: Th3pwn3r
Post Number:...
Post Number: 6742
"blah..a watt is a watt.. same board same amp, to some degree...u will not be able to tell a difference..."
If you really believe that you're a total moron. If they use cheap and high resistance conductors inside the board and use the cheapest parts that are at times faulty versus an amp with the same board using great quality conducts and parts you'll have a much stronger,cleaner and reliable amp. Stop posting retarded statements please. Do you even think about what you're saying before you post? Now I'm not bashing either amp here but you guys really need to use your brains before you go posting random bullsh1t.
Username: Nd4spd18
Northwest PA
Post Number: 6022
^^^^^^ right on
And obviously I didn't build either amp. Hifonics and AQ both have reputations for how good their quality is, and most of know which ones a lot better.
Post Number: 13709
"If you really believe that you're a total moron. If they use cheap and high resistance conductors inside the board and use the cheapest parts that are at times faulty versus an amp with the same board using great quality conducts and parts you'll have a much stronger,cleaner and reliable amp. Stop posting retarded statements please. Do you even think about what you're saying before you post? Now I'm not bashing either amp here but you guys really need to use your brains before you go posting random bullsh1t."
Like I said you will not be able to tell a difference besides in your wallet...And if you feel comfortable believing so, thats all up to you
"And obviously I didn't build either amp. Hifonics and AQ both have reputations for how good their quality is, and most of know which ones a lot better."
Honestly I have heard of about more DD/Audioque subs blowing then Hifonics amps failing..Its all about how you use your equipment, I have seen Cheap a.s.s amps running for 5-10years+ without a single problem, and still work fine...
Not saying i would choose the hifonics over the Audioque, just stating facts...
WEST COAST RD AUDIO
Post Number: 17852
lol same board. thats funny
Username: Th3pwn3r
Post Number:...
Post Number: 6763
""If you really believe that you're a total moron. If they use cheap and high resistance conductors inside the board and use the cheapest parts that are at times faulty versus an amp with the same board using great quality conducts and parts you'll have a much stronger,cleaner and reliable amp. Stop posting retarded statements please. Do you even think about what you're saying before you post? Now I'm not bashing either amp here but you guys really need to use your brains before you go posting random bullsh1t."
Not saying i would choose the hifonics over the Audioque, just stating facts..."
You didn't state any facts dumb a ss.
Username: Ctmike
Ct.
Post Number: 5813
"You didn't state any facts dumb a ss."
Username: Cblaze
Post Number: 1703
imo ppl just go by the name a amp has on it more than anythang.
Username: Nd4spd18
Northwest PA
Post Number: 6035
Thats all you can really go by, the company's rep for their quality.
I hope DJ from Audioque sees this thread. I'm sure he'd have something to say about the 1200d being the same amp as a hifonics........
Username: Cblaze
Post Number: 1704
well no offence to him but he is gonna take up for aq since hes with them.i mean what else do u expect
Username: Nd4spd18
Northwest PA
Post Number: 6037
Hifonics
Amplifier Class N/A
Number of Channels 1 - Mono
RMS Power (4 ohms) 550 watts x 1 channel
RMS Power (2 ohms) 1100 watts x 1 channel
RMS Power (1 ohm) 1600 watts x 1 channel
Bridged RMS Power Not Bridgeable
Peak Power Output N/A
Minimum Impedance Unbridged 1 ohm
Minimum Impedance Bridged Not Bridgeable ohms
THD at Rated RMS Power <0.1%
Speaker Level Inputs Yes
Preamp Outputs Yes - 1 pair
Built-in Crossover Yes - LP
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency 35 - 250 Hz
Subsonic Filter 15 - 50 Hz
Signal-to-Noise Ratio >95 dB
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled N/A
Fuse Rating 160A (80A x 2)
Audioque
Frequency Response 20Hz--250Hz
Signal to Noise Ratio 100db
Low Pass Crossover 24db / Oct
Low Pass Crossover Range 20Hz--200Hz
Subsonic Crossover Range 10Hz--50Hz
Input Sensitivity 0.2V--8V
Output Master / Input Slave Connection Yes
Working Voltage 8V---16V
Efficiency @ 4 ohm 84%
Damping Factor Less than 150
Fuse Rating 40Amp X 3 (Linked 240 Amp)
Output Power 14.4V @ 1% THD 510X1 @ 4 ohm,
870X1 @ 2 ohm,
1200X1 @1 ohm
Output Power 14.4V @ 5% THD 1470X1 @ 1 ohm
Dash Mounted Remote Included
Still think they're the same amp?
Username: Jkidder
Gunshine , State Flawda
Post Number: 3177
just laid out the same. same board but different components
