Please help!!!!
Username: Ska
Post Number: 213
ok, i've gone to many other forums (including "clublexus.com") and they didn't help with sh!t, but could someone help me fine which wire is the power antenna wire on a 1998 sc300? i've tried 8 different wires and can't get it to work, does someone have access to a wiring diagram for this car if so PLEASE send link
Username: Snarl2004
Digital Design 9515, Massive Audi...
Post Number: 2048
I had to find re power antena wire for a explored onceand here's what I did.
I unplugged the harness from the by andrew antenna went down. Then I took a wire and attached it to the 12 volt power wire then touched the other end to all the other woes in the harness untill the antena went up so I knew that was the power antenna wire
Username: Ska
Post Number: 215
see when my after market deck was installed they didn't make a harness for the car, so all my wireing back there is n!@@er wrigged, so each time i try and find a new wire i make it worse and worse back there:-(
Username: Ctmike
Ct.
Post Number: 5764
"n!@@er wrigged"
wont get much help here using comments like this.
Username: Ska
Post Number: 217
lol what else is it called?
The back of my deck is so unbelievably dissorganised because the people that installed the head unit were unable to come about a harness so the used thier cunning intelect by using different items other than the ones recommended by the factory
sound good enough for you?
Username: Nd4spd18
Northwest PA
Post Number: 5804
Come on now, lets use politically correct terminology here people.
It's afro-engineered...............
Username: Ska
Post Number: 218
^^^^^ AHAHAHAHHA
