13w7 vs. Two RE SE 12s
Username: Skibum12189
Cleveland
Post Number: 2497
Running of a Nine.1 both would be ported. Which would you take? Also, i know most hate this question, but which would get louder?
Username: Loudon
Post Number: 2227
id take neither personally
Cleveland
Post Number: 2499
what would you take besides those?
Username: Mendonmafia
Post Number: 833
in terms of spl i would have to go with the 12's. more cone area. the se's cost ALOT less to, so thats probably what i would take. i dont think i would ever buy a dub7. to many other, cheaper options.
Username: Denali_on_22s
Post Number: 3663
the nine.1 wouldn't push enough power for the W7. no one notices, but it's RMS is 1500 watts. That nine.1 at 3 ohms will probably produce around 675 watts... less than half the power the W7 needs. so basically i don't really think you have a choice. it's the RE SE's or a new idea.
Username: Extrmndor3
Http://illuzonemu.serv..., ^^^Sick Game
Post Number: 7572
ill take the jl.. and one of the facts that i will have a 13w7 in the back.. umm good
Username: Ska
Post Number: 173
i'd take RE, JL is over rated
Post Number: 7573
what????????? overated??
expensive is another thing..
and originality and exclusive is expensive...
thats why but i wil never say jl is overated
Username: 420alldaylong
Post Number: 3212
JL is not overated its overpriced.
And I would jump on the RE SE's.
Username: Drant19
DUB-C, TX
Post Number: 254
i wish i had the money for JL lol...but reece brassler brings up a good point. that amp will not give a 13w7 enough power for you to see it really shine. go with the RE SE's
Username: Loudon
Post Number: 2229
im personally not a fan of SE's ... they sound alright but the output isnt what i expected
W7s are great woofers ... but they sound muddy .. not a fan of their sq .. loud but sq not so much in my opinion
Post Number: 3668
that 13W7 would laugh at 675 watts. not to mention it wouldn't sound nearly as good.
Cleveland
Post Number: 2502
Well, actually reece i talked to the ED techs and they said at 3 ohms, the nine.1 is pushing 900 rms at 13.9 volts (my car's resting) which is plenty considering it's actually rated at 1000 and blaine westropp on here has a 13w7 on a nine.1 and it slams.
i'm not going for spl either, i just want some nice clean sounding bass. I've heard a 13w7 sealed and ported, a 12w7 HO box, and a single RE SE 12 sealed, and I liked the 13w7 ported the most, but the SE seemed to sound clean and get loud. I can get the 13w7 for like 370 too, the SE's would run about 325 a pair.
Username: Mj23dynasty
They Love 2 Hate Me, Most Hated a... USA
Post Number: 1144
Yes RE SE I am deeply in love with them if I dnt like the dd's I'm selling them and getting the SE's in a heart beat
Cleveland
Post Number: 2503
mike, do you think se's sound cleaner than w7's?
Post Number: 3669
the 13 W7 is 1500 rms, bud. check the site. as for the nine.1 i forgot it was rated a 12.5v i would still put more power to it.
Username: Nickyp0219
Post Number: 388
13W7 DRIVER SPECIFICATIONS
13W7-D1.5
Free Air Resonance (Fs): 23.5 Hz
Electrical "Q" (Qes): 0.476
Mechanical "Q" (Qms): 7.517
Total Speaker "Q" (Qts): 0.448
Equivalent Compliance (Vas): 3.68 cu. ft. / 104.3 liters
One-Way, Linear Excursion (Xmax)*: 1.25 in. / 32 mm
Reference Efficiency (no): 0.269%
Efficiency (1W/1m)**: 86.3 dB SPL
Effective Piston Area (Sd): 107.35 sq. in. / 0.0693 sq. m
DC Resistance (Re): 2.41 ohm***
Nominal Impedance (Znom): Dual 1.5 ohm
Thermal Power Handling (Pt): 1500W
Driver Displacement: 0.21 cu. ft. / 5.9 liters
Net Weight: 52 lbs. / 23.6 kg
