Chad Or Any One With a Weird HU
Username: Dakangofkrunk16
Post Number: 988
Where can i get an HU adapter for thisUpload
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 1732
you mean the dash kit?
Check walmart, cc, bb, crutchfield.
What kinda car is it?
Post Number: 989
2006 ford taurus... the radio and A/c are connected as you can see... si im lookin for a dash kit that would possibly have knobs for the ac and a place for the HU
Rock Vegas, NC US
Post Number: 1734
http://www.autotoys.com/x/product.php?productid=9699
google is your friend
this one has the passanger air bag light. if you dont need it look around and you can find one without it
Rock Vegas, NC US
Post Number: 1735
http://www.amazon.com/Stereo-Install-Taurus-wiring-installation/dp/B000KL2LXI
w/o air bag light I think
Username: Loc_out
Santa Ana, Ca Resonant Eng...
Post Number: 1605
Did you try ebay??
RD 1000.1D with SI MAG...
Post Number: 17145
that is going to be a tough one.
my stock headunit had the a/c controls and everything so i had to get a special kit for it. i paid $150 for mine. it comes with the knob to control the airconditioning and stuff.
Rock Vegas, NC US
Post Number: 1737
it looks like on the ones I posted that he pops his A/C knobs off and reuses them... Doesnt look too hard. The first one comes with keys to get the HU out too
Username: Loc_out
Post Number: 1606
Here you go 49 bucks
http://cgi.ebay.com/SCOSCHE-RADIO-INSTALL-DASH-KIT-for-00-2006-FORD-TAURUS_W0QQi temZ120211749717QQihZ002QQcategoryZ85806QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Post Number: 17147
but that depends andrew. if all the cables are connect to one big plug, he will need some kinda adaptor. now behind that unit if the stereo and the other stuff are all connected separately, then he can just cut out the part where the stereo is.
Rock Vegas, NC US
Post Number: 1739
wouldnt the wiring harness take care of that? Ive never done an install like this one so I have no clue what it looks like behind that. haha
Post Number: 17149
best way to determine is to take that dash apart and take some pics. lets see what it looks like behind that stereo and inside your dash.
Post Number: 990
http://www.amazon.com/AMERICAN-INTERNATIONAL-FMK578-Amer-Install/dp/B0002EXLVO
Pretty cheap... Hey thanks every one that helped me
Username: Nd4spd18
Northwest PA
Post Number: 5662
Yeah that kit is what you need. Be glad you don't have the digital climate controls in that car, as far as I know there is no kit for that.
