HO alt squealing question??
Username: Mixmastaspig
Canada, Canada Canada
Post Number: 1421
Just thought I would ask this as I am not sure what the problem is. This has been happeneing since day 1 of my alt (2006 sometime)
I have a 200a excessive amperage alt and when I start my car up the belt slips on the alt (you can see it hesitating while trying to spin) and squeals until it warms up a tad.
Now all is fine until I come to a stop and idle (until the car is warm) or when I crank my stereo up (loud), my voltage drops and it starts squealing again and slipping.
My belt is as tight as it goes and is in fine shape. I think it's just weird as it's fine until there stereo is turned up. I was thinking about just looking at getting a new belt tossed on, and doing to big 3 as well.
Any ideas?
Thanks!
Username: Talon01
Team revolution , Pa Usa
Post Number: 716
try a belt
Username: Northomaha
Post Number: 678
you should do the big 3 anytime u upgrade your alt, do that and get a belt that is maybe 1/2" shorter.
Username: Talon01
Post Number: 718
why a shorter belt?
Username: Nd4spd18
Northwest PA
Post Number: 5509
EA
^^^^ my guess what the problem is
Post Number: 1424
I will buy a new belt and I am just waiting on a spool of 0awg and some heat in the weather (car is under a foot or so of snow).
Username: Extrmndor3
Http://illuzonemu.serv..., ^^^Sick Game
Post Number: 7510
pully or your belt
Post Number: 1425
Is the pulley cheap/easy to fix?
IM THE REAL SLIM SHADY
Post Number: 16879
get a shorter belt. the pulley on your ho alt is probably smaller than your stock pulley.
Username: Nd4spd18
Northwest PA
Post Number: 5516
Well thats easy as sh!t to tell...... just look at the marks on the tensioner and see if they're not lined up.
And how could you not notice that when you installed the alt.
