Whats a good amp
Username: Devink
Op, Illinois
what is a good amp for a 15 inch type r with dual 2 ohm voice coils? is this one good? http://www.cartronixplus.com/templates/detailnf_price.cfm?zq=47967458&uas=N&glob aldesc=na&rnumb=883&wherefrom=SEARCH&whichord=270196&department=ALL&class=N&spec ial=R&tablegraphic=%2Fimages%2F&sold=N&nextrow=Kenwood%20KAC%2D9103D%20Mono%20Am plifierAMPkac9103d&prevrow=Kenwood%20KAC%2D9103D%20Mono%20AmplifierAMPkac9103d&n extprev=0&subclass=ALL&subname=na&pagename=Online%20Store%20%3E%20%20%20%3E%20AL L%20%3E%20&CFID=253823&CFTOKEN=74ebff9598225e7d-63842201-9027-14E6-E64575210ED04 5A1
Username: Nd4spd18
Northwest PA
Post Number: 5281
Hell no. Kenwood sucks........
rockford fosgate t5001bd would be great that amp will do at least 800w, it's underrated.
US Amps MD-1D
JL Audio 1000/1
If budget is a problem you could get a hifonics 1206d. That amp is ok but nowhere near as good as the others. It's overrated and will do ~900w
Username: 04redmach1
Lagrange, GA USA
Post Number: 1606
If your budget allows, I can help you with a RD 1000.1 or Sundown 1000D :-)
Kevin
lowhz01@yahoo.com
Username: Mixmastaspig
Canada, Canada Canada
Post Number: 1403
I would give that sub no less then 1,000rms myself.
Give Kevin a shout about the amps (I've bought from him/RD a few times so far) and what MS listed are good choices as well and if your budget is tight Hifonics is a failry good budget amp.
Stay away from Kenwood, Sony, pyle, boss...etc
Username: Nd4spd18
Northwest PA
Post Number: 5300
Those amps that Kevin posted are also good and he has good prices so check those out.
Lagrange, GA USA
Post Number: 1607
Very appreciated guys :-)
Kevin
Username: Devink
Op, Illinois
do you think thats why i keep popping fuses when i turn it up, is the alpine too powerful for the kenwood?
Username: N2audio
Lawrence, Ks USA
Post Number: 1440
amps don't care what's connected to them as long as they're stable at that impedence. You could have a 50,000w sub - as long as it's no less than 1 ohm the amp "should" run fine.
However, from what I've read most of those kenwood amps that are supposed to be stable at 2 ohms or 1 tend to struggle when operated at 1 ohm. That may be your problem
Username: Nd4spd18
Northwest PA
Post Number: 5337
Yeah, they kenwood amps that claim to be stable at 1 ohm are actually not, the are known to blow when run at 1 ohm.
Username: Msand951
Riverside, Ca Usa
Post Number: 17
are crunch any good do you think that the 1500 mono.
http://www.ikesound.com/product-product_id/4998 can perform close to the kicker 750zx. i want to match it up to the one 12 sounstream sub enclosed box
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16056 i heard that the 750 kicker is a great match but to expensive. and the crunch is 1 ohm stable.
Username: Nd4spd18
Northwest PA
Post Number: 5395
crunch = not good
BTW thats a max rating, it doesn't actually do that power
Username: Msand951
Riverside, Ca Usa
Post Number: 18
thanks MS
any recommendations other than hifonics thats close to the 750zx kicker. my little sis has one and damn its flawless. but expensive. or where can i find a refurb
Username: Msand951
Riverside, Ca Usa
Post Number: 19
just for kicks which is better . 750 kicker or the 1800 watt kenwood.http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17788
cause my bro in law has the kenwood and says his its better but his is pushing 2 infinity 12 reference and shes pushing 2 12 pioneers 450 max watts per speaker. but i was recommended for her to get the soundstream sub since she only wants 1 12inch.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5122
kicker FTW
Username: Msand951
Riverside, Ca Usa
Post Number: 20
Username: Msand951
Riverside, Ca Usa
Post Number: 21
whoops i taught it didnt post.
thanks for the answer
