Newbie Question Pertaining to More Power
Username: Rellikfl
New Port Richey, FL USA
Post Number: 25
If my current car can only support about 1000Watts without upgrade, how can I power a 2000RMS 4000Peak sub? Could I hook it to a red cap battery or something?
Username: Moey_g
SydneyAustralia
Post Number: 176
What amp are you going to be running?
Username: Rellikfl
Post Number: 26
don't know yet. Havnt bought one, thats why Im asking.
Username: Rideredder
Cornell, IL USA
Post Number: 1239
You're going to need a bigger alternator for 2000rms.
Username: Jtown
Team Revolution, Texas
Post Number: 1424
if you are running 2000wrms you're going to need a 180 amp HO alternator most likely
Username: Rellikfl
Post Number: 27
aight, thanks for the help!
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 198
HO alternator, gettin a bigger battery wont make a difference unless you have the charging system. and for the HO you want to get 200amps or higher if you going to run 2000rms...
Username: Vtouch06
Q-TowN, PiStoLvAniA
Post Number: 199
also you will need to do the big 3 upgrade.
Username: Nd4spd18
Northwest PA
Post Number: 4842
HO alternator definetly
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 1022
^^ho
Username: Basebalz13
Moneta, Va Usa
Post Number: 172
HO alt, big 3, and at least yellow top battery but kinetik FTMW
Username: Yukhui
3 15 AA Havocs, Memphis 4kw!!
Post Number: 813
What are you driving? Some rides can take 2k all day stock.
Username: Rellikfl
Post Number: 34
90' ford taurus
