Musical Bass
Username: Skibum12189
Cleveland
Post Number: 2185
What makes subs more or less musical...
I had SSDs but wanted more SQ so i got SI BMs. they sound awesome but aren't really musical. What makes a sub musical or not musical? I like listening to rap/hip-hop but eventually i get bored and put on rap, its prolly like 50/50, but when i play rock it almost sounds like my subs are choking haha idk it just sounds bad, how do i make em sound better?
Username: Mj23dynasty
Some where 12 wangin o..., The Mighty J... USA
Post Number: 767
diamond audio. RL-p or s
Username: Jkidder
Gunshine , State Flawda
Post Number: 2918
more musical is the better it blends in. its almost impossible to make a 15" 3000 watt sub sound musical because it will outpower any other speakers in the car... a more well defined component set and smoother response from the sub is musical.
Cleveland
Post Number: 2186
well i have Diamond S600S's i think thats decent enough...
idk i was just hopin to see more out of em...
would a better HU help...I remember my Premier making my sound system better than my Phase Linear....
Cleveland
Post Number: 2187
"smoother response from the sub is musical"
is there anyway to measure that or is it just a matter or liking the sound of the sub?
would an epicenter help? or some kind of pre-amp EQ??
Username: Jkidder
Post Number: 2920
mixture of both. your box has alot to do with it. the frequency curve in output plus the way it sounds to the ear.
Cleveland
Post Number: 2189
its sealed, will it sound better ported?
Cleveland
Post Number: 2190
bump
Username: Jkidder
Post Number: 2921
not really. whats your concern? is it too muddy, punchy??
Cleveland
Post Number: 2192
muddys a good word for how theyre sounding
Username: Ccdoggy
Post Number: 168
muddy usually means that they have a long decay time. the waves/pressure hangs around longer then the note, thus not allowing the definition in the notes you want.
It is a very hard thing to deal with in a car situation. Getting rid of reflections off hard surfaces, changing orientation of the sub can help.
