Orion hcca d2400
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 631
real wattage?
http://ampguts.realmofexcursion.com/Orion_HCCA-D2400/inside1.jpg
like that^^
Username: Naledge503
Http://com4.runboard.c...
Post Number: 2319
I'm pretty sure its rated at 1200 rms @ 1 ohm.
Username: Cblaze
Post Number: 632
i mean watt will it really do i know its rated at 1200
Post Number: 2320
Well being that the hcca-5000 does 2500@1 ohm and its the same line, I would bet that it does rated power or a lil more....
Username: Cblaze
Post Number: 633
i was just wondering of anybody on here had some numbers,from a bench or somethang
Post Number: 2321
In the words of Chauncey Brown. A watt is a watt. Whether the amp is of good quality or not thats a different story.
Username: Kyle_lowe
Post Number: 700
arent those amps the ones that took the places of the 1200d and the 2500d?
Post Number: 2322
yep
Username: Cblaze
Post Number: 634
yeah just gave them the marketing sheet,and put d2400
Username: Kyle_lowe
Post Number: 701
i would assume it will do its rated power then
Username: Kyle_lowe
Post Number: 702
1200d
hcaa2400
Username: Jtown
Team Revolution, Texas
Post Number: 962
me likey the 2400
Username: Cblaze
Post Number: 635
i might try it out
Username: Jtown
Post Number: 967
^if you do, post a review and what not....they look sexy, but I don't know about $700 for 1200wrms
Post Number: 2323
Looks can be decieving...check the T10001bd.
And we know what that baby can do.
Username: Cblaze
Post Number: 636
http://sonicelectronix.com/item_7559_Orion+HCCA-D2400.html
and yeah thats the truth i got the t5001bd(cheater amp)likes 41 watts doing double its rated power
