Something louder and better than a 9500
Username: Epidemic_wat
Clovis, California U.S.
Post Number: 23
i need a subwoofer that is louder then a mtx 9500. i have all the room so thats not a problem . just have to out take my friends system .thanks
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 13234
Budget
Post Number: 24
around 650 and i dont have the amp yet too.
Username: Basebalz13
Moneta, Va Usa
Post Number: 94
DD 9515 FTW haha that would kill 3 of those
Username: Jnoel
AIM= j69noel, KY
Post Number: 508
DD 9918- 540 shipped ftw email at ptownboy420@hotmail.com
Username: Mj23dynasty
Harrisburg star city, Pistolvania USA
Post Number: 302
Lol you could go with like 2 RE SSX's off ebay and a hifonics amp and tht would kill the MTX. OR you could go with a single sub setup something like a 15" Fi BL with a nice amp.
Username: 420alldaylong
Post Number: 2975
AudioQue HD3C 15"
Username: Nd4spd18
Northwest PA
Post Number: 4218
" DD 9515 FTW haha that would kill 3 of those "
^^^^^^^ X2
Even better get Jnoels 9918
Username: Jnoel
AIM= j69noel, KY
Post Number: 510
you will NEVER find a 9918 cheaper...theres one on ebay right now for 800 plus shipping
Moneta, Va Usa
Post Number: 95
yea that 99 would def kill that 9500 wouldnt even touch them lmao..... FTW J Noels sub pretty damn cheap and i think hes a great guy in need of sellin his sub.. if i hadnt already gotten everything for 2 15's id def be gettin that sub
Post Number: 26
i was lookin at alpine type x. i heard nothing but good things about that sub?
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 2...
Post Number: 5599
The Type X is more leaning toward SQ...not loudness.
Do you already have an amp?
Post Number: 27
o, no amp yet
Username: Hdubb
Team Revolution
Post Number: 3008
the 9500 is a good woofer, just needs the right enclosure. just thought id clear that up. lol. you dont have many options with 650 for the amp and sub, plus wires.
my advice is the audioque hdc15 and a ed nine.1 the hdc15 will run you 280 shipped. which is a great deal for a new sub. it has a ton of potential as well. the nine.1 will run you 295 shipped. great underrated amplifier. the sub will like a box thats 3.5 to 4 cu. ft tuned from 35-40 hz for daily musical listening. audioque has great customer service and would be happy to assist you with any othr questions vi email at sales@audioque.com
Username: Yamahabanshee1
Paulding, Ohio USA
Post Number: 427
15" Memphis Mojo
Username: Safe_cracker
Chicago, IL US
Post Number: 3783
My Treo SSX 15 dual 1's I have for sale! $350 plus actual shipping.... Polo..
Username: Tejcurrent
Post Number: 831
The type-x won't be louder, but they sound good in the right enclosure. You didn't say what size woofer he's running, or how much power. Just assuming a 15 with the recommended 1krms, that still doesn't say what car he has and what you have. So many things go into 'whats louder' that it's hard to say, but with more power and cone area you should have a good advantage:
If you have "all the room" I'd go for a Fi BL 18 (dual 2ohm coils, cooling, flatwind coil) shipped for 369 (ficaraudio.com). Tuned around 32-34hz this sub sounds amazing.
A Hifonics Bxi2006d amp will give you around 1800 watts for about 303 shipped (http://cgi.ebay.com/NEW-07-HIFONICS-BXI2006D-MONOBLOCK-AMP-2000W_W0QQitemZ220176 168335QQihZ012QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem)
You're looking at about 675 shipped for both combined.
For $25 more than you're budget it's well worth it, and if you need to stick below 650 go with the hifonics 1606d.
If you need wiring you should check ebay or knukonceptz wiring. There are other things you can get, but that's really
Post Number: 832
^but that's really up to you.
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 560
i vote the dd
Username: Th3pwn3r
Post Number:...
Post Number: 6029
"around 650 and i dont have the amp yet too."
If that's your budget you probably might not want to buy the amplifier and charging system for the mentioned subwoofers above.
Post Number: 28
k thanks
Username: Th3pwn3r
Post Number:...
Post Number: 6035
I wasn't trying to steer you away Ruben you can still get something decent for 650 dollars but you can't support a high power amplifier on a stock alternator and charging system which will easily cost you 400 dollars or more and then you'll need a pretty good amplifier and every penny adds up as you go and it gets expensive that's for sure.
Post Number: 29
another question i had is are cut threws any good? i heard they tend to leak water inside the cab?
Post Number: 840
Blow-throughs/cut throughs are great. They can really pull some great #s spl wise, and if done right shouldn't leak at all. If you don't know what you're doing though they can be a mistake.
Username: Bernymac
Turtles have four legs
Post Number: 3474
what amp does your friend run and what kind of box is he using.
