Gold Member Username: Nd4spd18Northwest PA Post Number: 4206 Registered: Jul-06 | I just got done installng my components 2 days ago, and I already want more power on them Right now I have a US Amps AX-TU300 which is 100w X 2. My speakers can take 180 watts so, I want an amp that does around 200w X 2 Either a 2 channel amp or a 4 channel bridged to 2 is fine. Would like to keep it under $300. This is the only good amp I've come up with so far http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5311} So what else is out there? |
Gold Member Username: LoudonPost Number: 2032 Registered: Jun-04 | look into the xt1600.2 ... the xterminator series amplifiers are alittle overrated .. but the 1600.2 will do around 180 at 4 ohm per channel |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4209 Registered: Jul-06 | The 800.4 that I posted does 260 x 2 and costs a little less........ And the XT amps aren't really "overrated", from what I've seen they are accurately rated at 14.4 volts. Its just most electrical systems do not run at quite that voltage. |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4227 Registered: Jul-06 | Bump any others |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4240 Registered: Jul-06 | I guess not lol |
Silver Member Username: Mj23dynastyHarrisburg star city, Pistolvania USA Post Number: 379 Registered: Oct-07 | heres an ok amp Infinity Kappa 202A amp. |
Gold Member Username: AdddisorderPalm Beach, Florida Post Number: 5496 Registered: Jan-06 | PG X200.2 |
