Subs inside out or reg
Username: Dj_excite
Post Number: 133
i got a pair of audiobahns a friend gave me the rubber surround is beet up so i was thinking of fliping them inside out i have done this b4 but in a bandpass box not sealed .....how would it sound should i or no
Username: Naledge503
Http://com4.runboard.c...
Post Number: 2234
No sound difference. Just for bling factor. Which will work perfect cause you got the bahns..
Username: Logan__tille
HEMIKLR
Post Number: 9073
It might sound a little bit boomier, but you probably wont notice.
Username: Th3pwn3r
Post Number:...
Post Number: 5915
"It might sound a little bit boomier, but you probably wont notice."
Why would it sound "boomier"?
Username: Dj_excite
Post Number: 134
i think he saying it will sound boomier since the speakers are more exposed to the trunk and it will b using the trunk as another box.........i dont no thts wat my common sense is telling me but thanx ppl.
HEMIKLR
Post Number: 9074
Because Rob, It will have more box volume when you invert it.
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 479
audiobahns are not my fav,but i guess u cant complain since they where gave to you.id just seal them and be done with it
Username: Th3pwn3r
Post Number:...
Post Number: 5922
"Because Rob, It will have more box volume when you invert it."
So the more volume you have in a box makes it "boomier".Hmm...I'm going to make a 40 Cu Ft box because it'll be boomier than my box that's 16 Cu Ft.Sweet!
Username: Nyyfan13
Fi SSD USA
Post Number: 7090
http://www.glasswolf.net/caraudio/inverted.html
Username: Van_man
Boston South, MA
Post Number: 3108
may want to reverse the polarity too. Try it both ways, and see what works better.
Username: Stamant
LA, FL USA
Post Number: 330
How do you reverse the polarity of the subs?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 12103
A pic is worth 1000 posts!!
Post Number: 11175
I'm seeing double.
Username: Nyyfan13
Fi SSD USA
Post Number: 7094
i have the exact same post as glasswolf....that means im as smart as him in this thread :-)
lol
Post Number: 11179
Lol, yeah but they're both pointing to HIS website.
Beat that.
Username: Nyyfan13
Fi SSD USA
Post Number: 7096
lol im gonna overlook that fact paul
HEMIKLR
Post Number: 9078
Yep Rob, thats pretty much it. The bigger the box, the louder it will be
-apem
Post Number: 15752
"i have the exact same post as glasswolf....that means im as smart as him in this thread
lol"
Username: Nyyfan13
Fi SSD USA
Post Number: 7098
