Help with setting gain...
Username: Dubmc23
Rapid City, SD USA
Post Number: 114
ok i have 2 type r's wired to 1 ohm on my kx1200.1 hot much of the gain could i push but not so much to blow the subs...the kx1200.1 benched just over 1400...
Username: Ctmike
Ct.
Post Number: 5395
use a dmm. or until your start hearing distortion, then back off a little.
Username: Dubmc23
Rapid City, SD USA
Post Number: 115
dont have a dmm :-(...but if i buy one what should it measure?? or would i just have to find out my self??
A pic is worth 1000 posts!!
Post Number: 11191
Dude, dmm's are so cheap and widespread. Sears, pep boys, autozone, even cheaper places like harborfreight.com will have them cheap as heck.
Username: Ctmike
Ct.
Post Number: 5398
buy a dmm and then use this:
http://www.subwoofertools.com/forum/setgain.asp
Username: Tatonka
-[Team Audib...
Post Number: 1044
ctmike said it perfect. A dmm is cheap and overall handy. That link will explain it all to you
Username: Dubmc23
Rapid City, SD USA
Post Number: 119
alright thanks guys ill have to pick one up here soon...
