OHMS
Username: Comerz
Post Number: 15
What is better? the higher the ohm, or the lower the ohm. I went to my local audio shop and he told me the lower the ohm, the better.
For some reason that didnt sound right.
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 1888
The higher the ohm the less resistence there is so the amp is usually more efficient.
The lower the ohm the more power you get. For example an amp that does 1000rms at 1ohm would do about 500rms at 2 ohm and 250rms a 4ohms.
Username: Comerz
Post Number: 16
k thx man that helps a lot
Username: Glasswolf
Wisteria, Lane USA
Post Number: 12106
um, no.
higher ohms = higher resistance.
go to www.bcae1.com and educate yourself please.
Username: Basssquared
Kansas
Post Number: 1508
:-) GlassWolf PWNING niggas since day one
