Best sub in small space?
Username: Jjproductions
Post Number: 19
Hey. Friend just bought a new truck (funny, its almost like the one I just bought) and has a little more space than I do in back. Hes got bout 7.5" on the bottom and 5" on the top behind his seat... 2000w rms to spend. What are the best two subs to put back there (need two for stereo...)? Thanks.}
Username: •cam•
Post Number: 977
You don't run subs in stereo. You just get cancellation then. We need a little more info.
Username: B3n07
Louisville, Ky USA
Post Number: 508
why not skipp puting them in the cab putem in the truck bed then you can go big
Username: Nd4spd18
Northwest PA
Post Number: 3647
" You don't run subs in stereo. You just get cancellation then. "
Right. Subs are run in mono no matter how many you have.
" why not skipp puting them in the cab putem in the truck bed then you can go big "
Probably because that's more work than most people want to do.
You need to give us the max space in cu.ft. that he has available. And I'm betting it will only be enough for 1 good sub........
Username: 420pimp2
Post Number: 815
Just tell him what would be an ideal sub for a sealed small enclosure. Give him the best idea u can think of for the smallest enclosure u can think of.
No specs just an idea is what hes asking.
Username: Th3pwn3r
Post Number:...
Post Number: 5577
Well...considering the dimensions he gave really don't give me a mental picture of what space he has...I can't really recommend anything.Put a 10'' sub in there or maybe two beefy 8'' drivers.
Post Number: 20
Not sure on the exact measurements.
@BEN: Maybe he actually uses his truck for work so has no room for subs back there... I know that's a hard concept to grasp.
@PIMP: Thats pretty much what Im trying to figure for him. Just something... probably anything less than 1.5 or 1.25 cu. ft.
Thanks.
Post Number: 21
1.5 or 1.25 cu. ft. behind each seat, I meant to say.
Post Number: 23
Bumped.
