How would you rate Edead sound deadening material ?
Username: Shak180
Hayward, California Usa
Post Number: 29
how good is Edead the sound deadening material?
would you guys recommend anything else?
or is it really good?
how much of it would i have to use?
multilayer necessary?
thanks in andvance
Username: Northomaha
Post Number: 572
its good stuff, i doubled mine up just on the trunk lid and rattles are at a minimum. the best stuf was the liquid kind i heard
Username: Th3pwn3r
Post Number:...
Post Number: 5487
I've heard that it's very good as well.Everyone says it's much better than Dynamat and it's cheaper by far.You can also look into FatMat and Second Skin.
Username: Tejcurrent
Post Number: 714
We just did the entire interior of my bros truck with the v1, seems to work good. It's held up to the heat okay so far, and it made a huge difference after 3 layers. Price is right.
Username: Th3pwn3r
Post Number:...
Post Number: 5492
I think three layers of anything would make a huge difference lol.
Post Number: 719
^no joke lol. One layer wasn't enough, and he had some left over with 2 layers, so 3 went to most places. He ordered 100ft for a single cab chevy 2500. It sounds so much better- the road noise used to be aweful! We don't have his audio gear hooked up yet, but he just changed over from a bench to racing seats, so we're making a center console for his 12" BL (If I can't convince him to recone it to a 15" :-) ). I figure if $ isn't a huge issue it's worth it while you have the panels off.
Username: Shak180
Post Number: 30
on my 97 dodge neons trunk how much should i buy and what areas should i do?
whole trunk ? partial ?
Post Number: 720
just measure and figure out the square footage. 2-3 layers on the lid, 2+ layers on the floor and sides. I'd greatstuff the lid first though, fill it to the brim.
Username: Shak180
Post Number: 31
should i take out all the cloth covering in the trunk and do everything from the spare tire area up ?
Post Number: 721
I'd go down to the bare metal, leave the factory deadener, wipe down with acetone, and go for it. It's a lot easier than many people make it out to be.
Username: Shak180
Post Number: 32
what would you do to put the factory trunk stuff back on tho all the holes for the rivets will be covered pretty deep
Username: Cenus
Ohio
Post Number: 3731
i use v1se on my hatch and it greatly reduced rattles, of course this is after 3 layers and 4 in some spots, i used dynamat on my door speakers and it did a good job also, i really can't compare the two, but i do know the edead was a lot easier to install, for it was a lot stickier and more flexible when compared to the dynamat.
Post Number: 723
Just punch holes in the deadener where it's important to have it.
Username: Frkkevin
Post Number: 3946
eDead = Peal-n-Seal
Username: Shade
Moxee, Wa U.S.
Post Number: 429
when id id my dodge neon trunk, took "great stuff" and filled in the trunk lid holes. took a knife and scraped off access "great stuff", and put dynamt xtreme all over the lid, and the rest throughout the trunk, also note, cut for little squares for the liscense plate, put that between the plate and the trunk.
Username: Shade
Moxee, Wa U.S.
Post Number: 430
lemme rephrase that, take those little squares and run the screws throu them so that the liscense plate cannot touch ur trunk
Username: Shak180
Post Number: 38
what year is your neon jeremy ?
and do you have any pics of the install ?
Username: Shade
Moxee, Wa U.S.
Post Number: 438
it's an 02' sxt and lemme see
[url=http://img87.imageshack.us/my.php?image=sta60006lo5.jpg][img=http://img87.imageshack.us/img87/5982/sta60006lo5.th.jpg][/url]
[url=http://img179.imageshack.us/my.php?image=sta60111wb0.jpg][img=http://img179.imageshack.us/img179/5039/sta60111wb0.th.jpg][/url]
[url=http://img136.imageshack.us/my.php?image=sta60113si4.jpg][img=http://img136.imageshack.us/img136/662/sta60113si4.th.jpg][/url]
i know it's not the greatest pix but all i took at the time, i used a dynamat xtreme kit, and it covered about 90% of the trunk
Username: Shak180
Post Number: 41
whats that foam stuff, where did you get it from, and how much was it ?
Username: Shade
Moxee, Wa U.S.
Post Number: 441
i think it was 8 bux a can, it's called "great stuff" aka expanding foam, and home depot or lowes is where i found it, i went throu 1.5 cans, the only thing that rattles on my car now is my sunroof
