Gold Member Username: 420alldaylongPost Number: 2763 Registered: Sep-06 | Which one do you think is better? Kinetik vs Odyssey |
Gold Member Username: Nd4spd18Northwest PA Post Number: 3457 Registered: Jul-06 | Depends on what "better" is. Equivalent models of those two brands will have about the same amount of power. They both float at about the same voltage. Odyssey batteries are built with toughness are the primary goal...... good for putting under the hood. Kinetiks cost slightly less I think. |
Gold Member Username: Nd4spd18Northwest PA Post Number: 3458 Registered: Jul-06 | Also a tip if your looking at batteries: Stinger batts are actually Odyssey batts with stinger labels, and they usually cost more..... just throwin that out there |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 3853 Registered: Nov-05 | what about NSB? |
Gold Member Username: 420alldaylongPost Number: 2767 Registered: Sep-06 | Link please^^^^^^^^^^ |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 3857 Registered: Nov-05 | www.northstarbattery.com/ you might just google it to find more info |
Gold Member Username: Joebruce15 AQ HD3 Post Number: 1576 Registered: May-04 | Jack before you get even more cocky than you already are,if you google NSB this is what it comes up with http://www.google.com/search?hl=en&q=nsb&btnG=Search Most people wont know what NSB stands for, so stfu Mr. Google First cuz im the sh*t!! You lil richey b*tch mommas boy!! |
Silver Member Username: RenegadesrunLafayette, IN US Post Number: 984 Registered: Oct-04 | The Odyssey releases faster than the Kinetik. Therefore, it would be slightly better in a comp application. Daily, you wouldnt know the difference. IIRC. |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 3859 Registered: Nov-05 | for one im not a "richy boy b!tch mommas boy" so don't go calling me out.. and i never said i knew everything.. was simply adding to the list but i don't even have to defend myself lmao.. this forums been falling apart for months due to people like you and the over-run of n00bs .. ecoustics is lucky a lot of the older members still post here and try to help i simple said FOR MORE INFO GOOGLE IT .. cuz their website don't tell you anything about audio install uses.. so whats your beef? |
Bronze Member Username: Bigmatt1986Jacksonville, Florida U.S Post Number: 24 Registered: Aug-07 | BURNED!!!!!!!! |
Gold Member Username: CtmikeCt. Post Number: 5353 Registered: Feb-06 | i've always been curious, but what kind of system you have joey? |
Gold Member Username: HdubbTeam Revolution Post Number: 2689 Registered: Nov-04 | the stingers do release power and charge faster which is great for comps. but honestly i think id run an agm deepcycle battery for daily. have more storage capacity but also take a good amount of time to fully charge. imo but odessy and kinetik are both good choices and im sure youd be happy with either |
Platinum Member Username: Bestmankind-apem Post Number: 15486 Registered: Oct-05 | nsb 90 is a beast. it would put both of the batteries you mentioned to shame. if you can make room to fit one under the hood the you are good to go. make sure you train it well. |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 12396 Registered: Jul-05 | GREAT THREAD ! kinetic has been the buzz lately but looking forward to seeing some more responses .... } |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 3861 Registered: Nov-05 | nsb 90 in the trunk FTW |
Gold Member Username: HdubbTeam Revolution Post Number: 2690 Registered: Nov-04 | some classes for comps limit bat size per catagory and or how many bats. the rage now is 16v charging systems. |
Gold Member Username: Nd4spd18Northwest PA Post Number: 3471 Registered: Jul-06 | Northstar batteries are GREAT, for competition that is. They aren't meant to be used in vehicles, and aren't designed to stand up the environment under the hood of a car. They're great if mounted inside though. Hunterw: Odyssey and Stinger batteries are exactly the same thing in a slightly different case with different labels. One is not better than the other, they are the same battery. |
Gold Member Username: HdubbTeam Revolution Post Number: 2691 Registered: Nov-04 | if i said they werent it was a error i know hey are they same as well as the tsunami bats same thing. dont mean to mis lead if it seemed if i was comparing two it was the kinetik and stinger. |
Gold Member Username: Nd4spd18Northwest PA Post Number: 3473 Registered: Jul-06 | Oh my bad then, I read that wrong |
Gold Member Username: 420alldaylongPost Number: 2769 Registered: Sep-06 | ctmike At the moment Sundown SAZ-1500D and 2 10" kicker L7's(I know I know L7's sound like sh!t but hey they were cheap.) |
