Need some help/advice
Username: Dubmc23
Rapid City, SD USA
Post Number: 23
ok heres the deal i have a kicker zx750.1 and a kicker kx1200.1...but i need to send them both in and have them renewed...will kicker just repair them for me?? and also if they do what subs should i get??
Username: Ctmike
Ct.
Post Number: 5337
if their under warranty they will fix them. given it's something covered. basically you'll get a new amp, old casing. and subs you should get, that depends on the amp you'll be running, budget, system goals, sub size you want, how many, etc.
Username: Dubmc23
Rapid City, SD USA
Post Number: 24
well neither amp is under warrenty have had the 750.1 for a while but jus got the 1200.1 and have no idea y its not working :-(...
