Mtx 9500
Username: Dc_shawty
Post Number: 13
mtx 9500- 800 watts peak power... got 2 of them...what do u reccomend for amp... im looking at hifonics cyclops 1 x 4000 @ 1 ohm
Username: Dc_shawty
Post Number: 14
also... its going to be in a range rover so i need reccommendations on what kind of box i should get sealed or ported.. im thinking sealed since i want sound quality but advice is appreciated
Username: Big_edge_head
Milwaukee, Wisconsin USA
Post Number: 657
peak dosent mean anything. and also the 9500s im pretty sure those can handle at least 1000rms
Username: Talon01
12 audioque 2.5 144.8 ..., Pa Usa
Post Number: 168
if going ported tune at 39-40hz
are they dual 4s,those subs are not really sq there more sql
Username: Dc_shawty
Post Number: 15
and the amplifier cyclops is good hifonics?
Username: Talon01
Post Number: 169
if you have to go hifonics a brutus 2006 would be fine i would rec. a mtx 81001d
Username: Dc_shawty
Post Number: 16
whats the difference for the mtx 81001d and hifonics cylcops?
Username: Dc_shawty
Post Number: 17
cuz look i wanna power them 2 da fullest and mtx does 1500 watts and hifonics does 4000 so??? haha i dont really know much about it but i mean da bigger da number da better u kno? but correct me if im wrong please
Username: Talon01
Post Number: 172
hows your charging system
Username: Dc_shawty
Post Number: 18
u mean my battery? battery isnt the issue im just wondering what amp would be good
Username: Tremor1127
Fi
Post Number: 2312
"u mean my battery? battery isnt the issue im just wondering what amp would be good"
haha, you can NOT run 4000 watts on factory electrical system on cars. you will HAVE to upgrade most/all of it.
you need an alternator for 4000 watts.
if you get a bigger alt i say go for the hifonics. they are decent amps just be careful with what you have.
the subs are loud, also. what size are they, ive actually heard several setups with them...
