Please HELP!
Username: Koondawg06
Post Number: 13
Hi, I could really use some help with hooking up my system I just recently purchased. I have two audiobahn 12" subs (see link) enclosed in a bandpass box, power acoustik plasma series amplifier (see link), and Power acoustik 3.0 farad capacitor.
Links:
http://www.cardiscountstereos.com/catalog%20page.asp?Product+%23=AW1251TPAIR
http://www.cardiscountstereos.com/catalog%20page.asp?Product+%23=TS19202
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D160158915547#ebayphotohos ting
OK, my question is, how do I hook up the dual voice coils? at first a friend and I tried hooking from pos 2. to pos 1., neg 2. to neg 1., then pos. 1 to box terminal, neg. 1 to box terminal for each subwoofer, but got no sound. Then we unhooked the pos/neg 2 to 1's from each woofer leaving one voice coil and now we have sound. But won't it sound better with both hooked up? What are we doing wrong? I am new to audio and this is my first system. A diagram would be most help full showing inside my box, to to my amplifier. Help will be greatly appreciated, Thanks in advance :-)
Username: Kingandsons07
Lincoln, Nebraska U.S.A
Post Number: 231
top one
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qt y=2&woofer_imp=4
Post Number: 232
try only hooking one sub up the first way you had it
Post Number: 14
here is a diagram of how we had it before and it didn't work.. hope you enjoy, homemade, lol
Post Number: 235
try only one sub i don't think u amp can do 1ohm??
Post Number: 15
what do u mean it can't do 1 ohm? I'm not quite sure by what you mean
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 12946
in ur pic..dont forget to wire up all the vc's...
Post Number: 16
keep in mind i'm brand new to audio.. don't really understand the ohm's and what not.. does this mean I can only have one sub going? Also, back to the diagram... there is a divider between my subs, what do i do there?
Post Number: 237
umm if u do one sub like u got in ur pic u got a 2ohms! if u do 2 subs like u had it wired its a 1ohm! if you want to do 4ohms u get less power!
4ohms is the boutom one in the pic
Post Number: 18
vc's? what are those?
Username: Rideredder
Cornell, IL USA
Post Number: 1001
You can run one of those subs at 2ohms, or both at 4ohms. You could wire them both up so the amp sees 1ohm, but that amp isn't 1ohm stable.
Post Number: 19
well.. the way i had it wired i got 0 ohms because I had no sound? :-)
Post Number: 238
yep yep just like he said u may get it loder at 2ohms. the sub's u got are dvc! dvc = Dual Voice Coil, svc = Single Voice Coil
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 1...
Post Number: 5341
you had that wired to 1ohm...you need it at 4ohm for your amp.
Do this to each sub:
Post Number: 239
u if u want to get more power u will need a diff amp that is a 1ohm stable.
Post Number: 240
he will be under powering them?
Cornell, IL USA
Post Number: 1002
At 4ohms, yes.
Post Number: 20
okay, so my amp isn't very good basically? This is how i have it now
It sounds pretty good that way, but it will sound better with the other voice coil connected, correct?
Post Number: 242
i think he should upgrad his amp soon and the amp needs to be 1 ohms stable
Post Number: 21
just bought the amp :-(, I thought the only difference was 2/4 channel, lol.. (I'm very new)..
Post Number: 22
is the way I have it wired now the reason I have troubles with my amplifier getting hot? and Also my capacitor stays on 24/7 and kicks off occasionally, just went out to my car to look at my box and my cap was on...
Post Number: 243
go and try it the first way u had it on one sub only to the amp like the top one. it should hit now and come back and tell use how it sounds then try it the 4ohm way but u will be under powering and see what sounds better to you
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qt y=1&woofer_imp=4
Post Number: 23
okay.. well, I'll be sure and try it tomorrow morning and I'll let you know how it sounds. Thanks a lot everyone :-)
Post Number: 244
maybe see its bad to do svc on dvc so go try it idk about capacitor i don't like them just to the big 3 and sell u capacitor! the big 3 works better then a capacitor
Post Number: 26
o well i was told the cap would store power so the head lights wouldn't dim at night... what do u mean by big 3?
Post Number: 246
u add 0g power wiring from the - of your batt to the car! 0g wiring from ur + batt to ur alt! then 0g wiring from you engine block to ur are!
Post Number: 27
Oh! Ok!.. Thanks for all your helpful advice Quentin, and everyone else as well!.. by the way Quentin.. I see you are from Lincoln Nebraska... How about them Tigers! MIZ-ZOU!.. ok, so that was mean to do, but I had to, or maybe u don't even care about college football, lol :-)
Post Number: 247
idc about that game but i love the huskers lol 6-40 idc 2 lose!
but if u need a new amp get a usamps xt1000.d http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5788
Username: Nd4spd18
Northwest PA
Post Number: 3318
" i was told the cap would store power so the head lights wouldn't dim at night... "
You was told wrong.....
Post Number: 28
what is the purpose of the capacitor then?
Username: Tatonka
-[Team Audib...
Post Number: 948
It's pretty. And some even have a innacurate volt meter :D
Post Number: 249
to get ur money lol
Username: Nd4spd18
Northwest PA
Post Number: 3323
Heh. Nick and Quentin about summed it up
Post Number: 251
yep yep
Post Number: 30
how come my buddies are going down the road at night and their lights are flashing to each beat? and mine aren't? lol explain that one :P... btw haven't tried hooking up the vc's i went turkey hunting today.
Post Number: 252
will they work a lil bit and i mean lil so u lights don't flash! but the big 3 will help out alot more and did it work like well told u??
Post Number: 31
"""btw haven't tried hooking up the vc's i went turkey hunting today."""
look up ^ :-)
Post Number: 253
what r u talkin about??
Post Number: 33
u asked in your last post if it worked well like you told me, and in the post before that I told u I went turkey hunting today so i didn't get the chance to mess with my system..
Post Number: 254
then go do it now!!!!!!
Post Number: 34
wired my subs for a 4 ohm load, sounds great to me, Thanks for all the help everyone!
Post Number: 256
i bet if u unhook one sub the other one will be louder
