Username: Santa_fe Post Number: 201 Registered: Jul-07
Wednesday, September 26, 2007 - 01:38 GMT Rockford Fosgate 201S Car Amplifier for 60 from friend????
Username: Santa_fe Post Number: 202 Registered: Jul-07
Wednesday, September 26, 2007 - 01:55 GMT bump ^
Username: Philly306 North carolina
Post Number: 411 Registered: Apr-07
Wednesday, September 26, 2007 - 01:57 GMT if friend is a hot girl then yes
Username: Santa_fe Post Number: 203 Registered: Jul-07
Wednesday, September 26, 2007 - 01:59 GMT no sorri its not....but should i get it....im pretty sure these amps are underrtaed anyone know specs on it?
Username: Hurricanebr1an Western Burbs of Chicago,
IL
Usa
Post Number: 83 Registered: Sep-07
Wednesday, September 26, 2007 - 04:33 GMT 4 ohm 50x2 2 ohm 100x2 bridged 200x1 rf amps are underrated and good quality do you have something specifically you're gonna push this with or just asking if its a good amp to pick up? theres 1 on ebay for $80.
Username: Gavbo211 JL Audio 10w3v2,
IL
US
Post Number: 596 Registered: Jan-05
Wednesday, September 26, 2007 - 05:16 GMT i have that amp.. it does it's job quite well. had it on my w3v2 for while and it pushed it pretty good. i payed 30 for mine.. but it was from a good friend who owed me. i'd say 60 is a pretty good price. what are you running with it?
Username: Santa_fe Post Number: 207 Registered: Jul-07
Wednesday, September 26, 2007 - 11:29 GMT well i might run a Dvc pro teknique with it....which is dual 4 0hms bit i think the amp is 2 ohm stable right???? So if i set the gains right i could push that subs with this amp right??
Username: Th3pwn3r Post Number:...
Post Number: 5083 Registered: Jul-06
Wednesday, September 26, 2007 - 12:15 GMT You can just about push any sub with any amp as long as it puts out enough power and is stable
Username: Santa_fe Post Number: 208 Registered: Jul-07
Wednesday, September 26, 2007 - 15:25 GMT thanx for the help guys....ill pick it up on monday...
