Alpine Type R - 1 cu. sealed
Username: Dub_c
Post Number: 309
Does anyone how this setup will sound with about 800wRMS?
Username: Northomaha
Post Number: 562
It should sound good. I would still port it. Especially with that much power. is it a 12 or 15?
Username: Rovin
4 10 Pioneer...
Post Number: 12186
when i had my 2 type i had them each in 1 cuft & it sounded quite good off a power acoustik amp rated 2100wrms .......
Username: Dub_c
Post Number: 310
I wish I knew how to make enclosures, it will be a 12", does anyone know of a place I can get a ported box that will work with that sub?
Username: Surferdude9371
Fully loaded 18 BTL
Post Number: 246
ur best bet is there are alot of talented box makers on here like logan post that u need a box made and youll get a bunch of responses im sure and shouldnt cost you that much for 1cuft box
Username: Rovin
4 10 Pioneer...
Post Number: 12187
u can always buy a 2cuft sealed prefab & port it with a 4" aeroport ...
Username: Dub_c
Post Number: 311
Naw I can get a good 1 cu sealed box almost anywhere, I'm wondering about a ported box that will work with the Type R.
ALSO, for a sealed box, will it make a sound difference if the box is 1.2 cu or 1.6 cu sealed?
