SVC?
Username: Freezeman_7
C.FREE
Post Number: 1726
What the F/uck does that mean?
its a setting on my headunit.
is it like the "loud" setting on other units.
its jus a basic settin on my eclipse cd5000, its with the subwoofer level. i have it on 5, and it goes to 10 i think. its waay louder, but i still dont know what it means.
Username: James1115
Use a simple...
Post Number: 10232
source volume control
Username: Imnothereimjustvisiting
Post Number: 89
look in the manual
Username: James1115
Use a simple...
Post Number: 10233
hey Justin the correct way of saying that is "RTFM" lol
C.FREE
Post Number: 1727
yeah i dont wanna find the manual.
nor do i wanna read the f/ucking manual.. lol
Username: The_image_dynamic
San Diego
Post Number: 2696
Source Volume Controls (SVC): Because the level of each source can vary greatly, the Source Volume Controls allow you to raise or lower the volume of AM radio, CD, and Memory Stick audio compared to the FM radio signal. The volume differences can be set within a range of -10 to +20.
C.FREE
Post Number: 1731
so brad it wont hurt anything to have it up/?
San Diego
Post Number: 2698
All it is for is when you play sources other than FM radio and switch back to FM it isn't blasting. I think I remember that you don't even listen to radio (I never do either) so just turn it off. The less circuitry between the source and the output the better.
