Silver Member Username: Big_fletchNewport, Ar, Ar United states Post Number: 665 Registered: May-06 | okay guys i recently had (2) 15 L7's powered by a kx 2500.1 amp and i drive a 2002 caddy escalade ive talked to steve meade and i told him im wanting to go bigger and louder and he told me why not (4) 18's and i said i dont have enough money for 4 btl's so me and him decided on either 4 18" Q's or 4 bl's...he is goin to build the box for me and its goin to be basically like his own box now i dont have any electrical updates done to the caddy but soon i will have a 300 amp excessive alt and im thinkin 2 2400 batts in the back and keepin the stock batt under the hood and doin the big 3 as for watt's im thinkin about 4000 to 5000 so what do u think i should go for the q's or bl's or re sx's lol or what thanks peeps |
Gold Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 1584 Registered: Dec-06 | for me it would be between the bl and the q ide get the q's because with 4 18"s it will be loud enough and the q's will have better sound quality. |
Gold Member Username: Skibum12189Cleveland Post Number: 1355 Registered: Mar-06 | on 4-5k rms, i'd personally go 4 15" Q's, it'd sound very clean and be very loud! |
Gold Member Username: 420alldaylongPost Number: 2436 Registered: Sep-06 | Q's |
Silver Member Username: Big_fletchNewport, Ar, Ar United states Post Number: 666 Registered: May-06 | do the Q's just sound cleaner than the bl's do? and if so how do the spl of the q's stand up against the bl's cause im really wantin to be loud... u think ill be able to do a hair trick with this if i go with the q's |
Gold Member Username: J_baby15Justin Noel ... Post Number: 1980 Registered: Feb-06 | 4 18s, nice size port, id say a hair trick shouldn't be tooo hard. man w/ 4 18s and that much power then you're gunna b loud as long as you do your stuff right. |
Silver Member Username: Mike11202Sewell, NJ US Post Number: 924 Registered: Nov-06 | 4 15" JBL GTi's and youll love it i owned a 15" Fi Q.. it seemed very loud but didn't hurt your ears at all, my JBL GTi MKII sounded better and got louder |
Gold Member Username: Denali_on_22sIm just light up my...... Post Number: 2662 Registered: Feb-06 | BLs and 5000+ watts... |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 4207 Registered: Jul-06 | Meh...my post dissapeared.You're going to need double runs of positive wire if you're planning on running 5k.Invest in some nice ground terminals too.If you HAVE to run Fi subs go with the BLs over the Qs.I wouldn't run them personally for whatever reasons but if you're going to...I agree with Reece. |
Silver Member Username: Big_fletchNewport, Ar, Ar United states Post Number: 667 Registered: May-06 | so why bl's over q's? |
Gold Member Username: CtmikeCt. Post Number: 4952 Registered: Feb-06 | never heard the bls' but supposedly they have sq close to the q with more output. |
Silver Member Username: Big_fletchNewport, Ar, Ar United states Post Number: 668 Registered: May-06 | i wish some1 here in arkansas had some of these subs so i could decide on what to get...how many watts do the suppose to hold...ive heard 1000 to 2000 |
Gold Member Username: Denali_on_22sIm just light up my...... Post Number: 2665 Registered: Feb-06 | BL will get louder. That's what you said you wanted. I'm personally with Rob in saying I would probably run something other than BLs or Qs. I would try the new Havoc or 3518s. |
Gold Member Username: JkidderSpring hill, Florida Usa Post Number: 1547 Registered: Nov-05 | bl is loud and sounds good. i'd go BL's out of the above |
Silver Member Username: Big_fletchNewport, Ar, Ar United states Post Number: 669 Registered: May-06 | what about the re sx's? will they get louder than the bl and q |
Silver Member Username: Big_fletchNewport, Ar, Ar United states Post Number: 670 Registered: May-06 | i was thinkin if i run a 1 rockford fosgate t4000 which u thing would be louder and sound better either 4 18's....bl's,q's,or sx's or 2 fi btl fully loaded or re mt and why...and u gotta think the escalade is a big suv and i can fit a huge box in the back and the 3rd row seat is out |
Gold Member Username: JkidderSpring hill, Florida Usa Post Number: 1550 Registered: Nov-05 | 4 18" BL's i'd pick. they r very efficient. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 4213 Registered: Jul-06 | Go with 4 DD 3518s |
Silver Member Username: Big_fletchNewport, Ar, Ar United states Post Number: 672 Registered: May-06 | will a 1000 push 1 good? cause im prolly goin with 1 rockford t4000 |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 4216 Registered: Jul-06 | 1KRMS would do a good job on them but you can run that Rockford a bit below 1 ohm as long as you can support the current demands. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 4217 Registered: Jul-06 | Tyler,do you have AIM?Hit me up on Getripped84 if you do. |
Silver Member Username: Big_fletchNewport, Ar, Ar United states Post Number: 673 Registered: May-06 | i got yahoo tyler_fletcher2008@yahoo.com |
