Better program than Limewire????
Username: Volfenhagking1600
SSD Wangin, Shawano, Wis... USA
Post Number: 873
Can someone help me out on what program i should download to give me better quality music...
Username: Moey_g
SydneyAustralia
Post Number: 108
have you tried using torrents?
Post Number: 874
no i dont know what torrents are...
Username: Moey_g
SydneyAustralia
Post Number: 109
well they are similar but a bit more difficult to use. But once u get the hang of it u will love it.
Well basically u need a torrent program such as bitcomet. (There are others but i use this one and it works well)
Once the program is all set up, u need to go to a torrent search web site such as www.torrentspy.com or isohunt.com
You search for what you want to download from these sites. Once you have found what you want, download the setup file and run it in bitcomet. (or whichever program you decide to use).
Thats all there is to it.
Username: Moey_g
SydneyAustralia
Post Number: 110
Oh, i just re-read your question. You wanted a program to give you better quality music...
Torrents wont necessarily give u better quality music, but they are better than limewire.
Username: Blazerboy
15 $$D wangi...
Post Number: 568
Yea, I get most of my music from torrents. I use bit torrent, and it has never failed me, so i recommend that.
Post Number: 875
once i have downloaded bittorrent what do i do then?
Username: Tatonka
Post Number: 749
mIRC using XDCC Send and fServe.
Username: Adddisorder
West palm, Florida
Post Number: 4968
use utorrent its the best client out, others pack in spyware and stuff.
Username: Tatonka
Post Number: 750
actully for torrents, Bitpump is the best program out.
West palm, Florida
Post Number: 4969
ok so my statement is a little outdated though, should have watched what i said.
Username: Jtown
Post Number: 203
I use utorrent and love it. I use btjunkie to find the torrents
Username: Wojopro
Summerville, SC
Post Number: 290
I love bitcomet.
Username: Mike11202
Sewell, NJ US
Post Number: 923
nah utorrent ftw
Username: Moey_g
SydneyAustralia
Post Number: 111
bitcomettttttttttttt lol
There are many of them, they all do pretty much the same thing in the end.
Username: Moey_g
SydneyAustralia
Post Number: 112
Jamie, once you have downloaded the software, u have to search for whatever it is you want to download using a torrent search website.
I explained it all in my post at the top ^^^^
If you have trouble following any particular step then let us know and one of us will assist you further
Username: Player104
Hmmm... i find torrents annoying and slow for small files that arent popular
if you're looking for music that isnt mainstream and you want songs that sound similar i suggest you try the blog scene
its not their own music, but they have a friend who has a friend who knows the band's bass player's brother etc etc
try the following music blog search engines
http://elbo.ws/
http://hypem.com/
search for artists or tracks, then open the blog and download the track.
i also use a program called Soulseek, good for house music but you can only download one file from a user at a time
Username: Moey_g
SydneyAustralia
Post Number: 113
Yea torrents are not that good for single tracks but they are great for albums
Username: Jtown
Post Number: 204
thats why you just download the whole album as a torrent and then when you start the download process with said program you only select the songs you want off the album. at least thats what utorrent allows me to do.
