How to check if amp works
Username: Rosrock2000
AA Assassins, MI USA
Post Number: 443
hello, i have an mtx 801d which is a decent amp and a respectable company. i bought if off ebay. now for the problem i accidentally hooked the ground and pos. opposite. anyways im not sure if this would cause the problem having seeing that the fuses did blow thank god. unfortunately im not sure if it worked when i got it. but anyways well my subs work cause i tested em out with a home receiver. however in my car they hit really randomly HARD like every 3-6 seconds a real quick hit and its terrible maybe its "bottoming out" cause like i can here coils or something in between its weird. i have to completely take off the face plate to. but do u think its the amp or could it be something else or maybe even the sony h.u.? maybe a bad ground ? apreciate any opinions
Post Number: 444
o and lol how do i check to see if it works thx
Post Number: 445
anybody? its kinda like a POP sound
Username: Thumpinwith8s
2 RE8s,PG Xenon 400.1, New Numbers ...
Post Number: 646
ok, disconnect subs, then use dmm to see if you are getting any powere from the amp
Post Number: 447
what should i set the dmm to?
Post Number: 648
put the dmm on AC and check your voltage coming out of the amp, to see if you have any
