Best material for box
Username: Mark872
Post Number: 26
alright im bout to build my first box for 2 twelves. I havent been in to car audio for too long so i dont know alot about it. what is the best wood to build a box with and what should i use to fill the seems. if there is anything else ill need please let me know
Username: Crayola0
Future 15 Wanger!!, Wisconsin
Post Number: 2035
the most normal is MDF but i remember a thread about this stuff called Trupan Light...but MDF is what mostly everyone uses
Username: Joebruce
15 AQ HD3
Post Number: 1272
id say cardboard. but if u want really good stuff go with plywood
Username: Jkidder
Spring hill, Florida Usa
Post Number: 1369
he's kidding ofcourse btw lol
mdf or trupan light but u have to go to lumber yard for trupan
Username: Mendonmafia
Post Number: 360
wow
Username: Joebruce
15 AQ HD3
Post Number: 1274
me kidding yo! but yes mdf or trupan=good stuff
Post Number: 364
glass?
Username: Thumpinwith8s
2 RE8s,PG Xenon 400.1, New Numbers ...
Post Number: 593
mdf or trupan for the box, liquid nail or something simular to seal it
Username: Kpa2727
Post Number: 485
loctite power grab i used on mine for a basic quick hoild then over layed all of it with gorilla glue. i'm going to give u the best advice since it was my first build, be prepared to sand with gorilla glue. in my eyes with gorilla glues epasion over flows the best cause u can sand it smooth and still have a extreamly good seal.
mdf 3 quarter is good, one inch i the best u can do but weighs and costs a ton. in most lows it's known as underlymeant but it's gotta be mdf aka medium density fiber board. oh and lots of clamps. i didn't have them and it was rough as hell to do it. mine from buying to the end of build took 13 hours and did it in one day. i also took a ton of time making sure everything was perfect to the best i could. if i do a new box which is still a possibility in the future it be alot faster but thats a rough idea for you. for a first box go with 3 quarter mdf, cost is roughly 23 bucks a sheet at a lowes or h depot. troupan i say leave alone till skilled so if u mess up no huge money loss. what makes boxes come out the best is a pencil, some time, a tape measure and a solid air tight glue bond.
Username: Mike11202
Sewell, NJ US
Post Number: 886
yeah mdf or trupan
then wood glue the sides together and if you have one use a nail gun to hold it instead of clamps
after the nail gun space out some screws into it
then silicon all the corners on the inside
Username: Mike11202
Sewell, NJ US
Post Number: 887
course thread 1 3/4" screws btw
