Worth it?
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 1459
At the moment i have 2 12" SD2.5's and i am thinking about upgrading to a HDC3 15" when they come out. I was wondering if you guys thought it was worth it to do. It will probly cost me about $1500 when everything is done. So would you guys think there will be a big difference and do u think it will be worth it to upgrade?
Username: Th3pwn3r
Post Number:...
Post Number: 3467
You're comparing two 12s to 1 15.Try it and see because nobody can say for sure,you should know that there are way too many factors in trying to tell you if it will be a big difference or not.I would definately get rid of those SD2.5s and switch to an HDC,I hate those subs.
Username: Dakangofkrunk16
Post Number: 697
why not get the 18
